I can't open my messages folder nor read my sms in my nokia n70
I can't open my messages folder. i can't read my messages. it keeps saying "system error". i've tried *#7370# but it ask for "lock code". i don't know what t give.my phone has been reformatted and updated already. help me pls. big thanks.
Download and install this File Manager - fexplorer.
Launch FExplorer and navigate to C: if you use Phone Memory to store your messages (default) and D: if you use Storage Card as your SMS location.
Now navigate to and open "system" folder.
Now open the "mail" folder.
This folder should contain many folders named similar to 0010001_s etc. with files named similar to 00100000 etc., These files are the actual deleted messages, Simply, use the FExplorer inbuild text viewer to view these files, You will need to browse through every folder and open all files inside them until you get the required SMS.
Do Note that this trick does not work on Symbian 3rd Edition cellphones.
1. Download and install this free mobile File Manager - (FExplorer). 2. Launch FExplorer and navigate to C: if you use Phone Memory to store your message (default) and D: if you use Storage Card as your SMS storage location. 3. Now navigate to and open system folder. 4. Now open the mail folder. 5. This folder should contain many folders named similar to 0010001_s etc. with files named similar to 00100000 etc., These files are the actual deleted messages, Simply use the FExplorer browse through every folder until you get the required sms.
1. Download and install this free mobile File Manager - FExplorer. 2. Launch FExplorer and navigate to C: if you use Phone Memory to store your messages (default) and D: if you use Storage Card as your SMS storage location. 3. Now navigate to and open “system” folder. 4. Now open the “mail” folder. 5. This folder should contain many folders named similar to 0010001_s etc. with files named similar to 00100000 etc., These files are the actual deleted messages, Simply, use the FExplorer inbuild text viewer to view these files, You will need to browse through every folder and open all files inside them until you get the required SMS.
Hi priyakaju,
Its very simple, This trick is for mobiles, you can restore sms messages that you have deleted in the recent past. you can get your sms messages back to your inbox by following a small trick that I found. Trick to read deleted sms. This sms trick is 100% working.
Required utility:
You will need File Explorer in your mobile phone. (Download from here)
Procedure to restore sms
• Open File explorer in your mobile.
• Select drive C: or D: depending on the memory in which the Sms messages have been saved.
• For example you selected c:, Then open "system" folder.
• Then in "system" folder open "mail" folder.
• Then in this folder you will see different folders (eg 0010001_s) and certain files (eg 00100000). These files are the actual messages. Browse through every folder and open all files till u get the sms u are looking for.
• For opening the files don't choose options>file>open as it will show format not supported rather choose options>file>hex/text viewer. By selecting the "http://gallery.mobile9.com/f/13774/?vie… u ll be able to open and read the deleted SMS message.
Please leave me comment, if you need further assistance
good luck with your fix,,, have a nice day,,
A VERY HELPFUL RATING IS APPRECIATED, Thanks Regards Arul
Step 2) Select drive C: or D:
C-phone memory D-memory card
Step 3) For example u selected c: ,
step 4) Then in "system" folder open
"mail" folder.
step 5) Then in this folder u will see different
Step 6) For opening the files
the "Hex/ text viewer" u ll be able to open and read the deleted SMS
message. Your rating is highly appreciated on this
matter.
Step 2) Select drive C: or D: depending on the memory in which the Sms messages have been saved. C-phone memory D-memory card
Step 3) For example u selected c: , Then open "system" folder.
step 4) Then in "system" folder open "mail" folder.
step 5) Then in this folder u will see different folders (eg 0010001_s) and certain files (eg 00100000). These files are the actual messages. Browse through every folder and open all files till u get the sms u are looking for.
Step 6) For opening the files don't choose options>file>open as it will show format not supported rather choose options>file>hex/text viewer. By selecting the "Hex/ text viewer" u ll be able to open and read the deleted SMS message.
"mail" folder.
message.
is it happened only when writing a message or in any condition. if only in sms message screen, then do a master reset. if any condition, then its a lcd problem
U received virus sms by blue tooth. To remove it scan ur memory card(with latest anti-virus) and format ur Phone(after backup it). U problem'll b solved.
