Televison & Video Logo
Posted on Mar 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I don't have the remote for the Zenith System 3 tv. How do I get the tv off muted? I have gotten the DISH remote to work on the tv but can't get sound since the tv says "muted"????
Anonymous
Level 3:
Genius:
  • Master 1,274 Answers
  • Posted on Mar 16, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1274
Questions
0
Helped
316145
Points
3479
Press the volume button. hope this helps..
Get my dish reciever, sony home theatre, and 55in sanyo tv to work together
If your TV and sound system both have a Digital Optical Out/In you can use a TOSLink cable (an optical cable) to connect your TV directly to your sound system, and remove the connection between the DISH receiver and the sound system. As long as your sound system is on the right input, all sound accompanying the picture on screen will go to your sound system. Most TVs also have an option to turn off the internal speakers, if not just reduce your volume all the way down to avoid that weird ghost sound effect. If you use your sound system all the time for volume, you can program the sound system to your DISH remote's AUX, and even set the remote so that it only sends volume and mute commands to the sound system (that way you don't have to dance between sat, tv, and aux all day, just leave it in sat mode).
To program your remote to the sound system, follow the instructions on the sheet you got with the remote (yeah, right like anyone kept that) http://www.mydish.com/support/remotecodes you can use that link to program your remote. You can also use the learning mode if your remote has a little glossy square on the top left side and you have the original remote to the sound system. (Learning mode can be gleaned from the remote manual Remote Control Manuals)
After programming the aux device, and verifying that it changes the volume up, down, and mute, THEN:
Hold AUX until light blinks 3 times, hit pound (#), Volume Up, 0 (Zero), pound (#), SAT, then test to make sure it goes up and down.
I have an ol RCA tv, new dish remote everything works but the mute button...i can raise and lower volume, turn off and on but not mute
Hi there Stacey, my name is Kimberly and I form part of the Social Media Department with DISH. We do not promise that our remote will control all the functions of you TV. The codes used to program your DISH remote to the TV may be limited to some functions. You can try addressing your remote to the TV using different codes. I have listed the steps below to assist with programming the remote to your TV. If you have any other questions, let me know at [email protected]!
You can lookup the different codes here: http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
Kimberly Escobar
Social Media Representative
DISH L.L.C
I need to program a zenith tv to work with the 21.0 ir/uhf pro remote control
Look up codes for TV here: http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Need to reprogram two dish remotes but cannot find the dish manual with the remote codes in them.
I would need to get a better idea of what model remote you have. I would recommend viewing our remote codes found here: http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
You can find the model # on the back of the remote at the top, and the codes on the above link.
To program remote to TV:
1. Hold the gray TV button until all lights on top of the remote turn on.
2. Let go and while TV is blinking enter the 3-digit code and press #.
3. Try to use TV functions like volume/power/mute.
4. If it works press SAT and you're good, if not repeat steps 1-3 with another code on the list.
Tommy Faust
DISH Network
Muted on Cerain Channels on Zenith SE2795W TV
Somewhere in it's lifetime, a user has set the 'user preference' to 'mute' while this channel was active. I don't know your specific set, but most TV's need a remote to work 'mute'.
Second hand set?
[A] check all buttons on TV for a crossed-out speaker symbol, or
[B] buy a universal remote and select pin for your set. Then,
Try these:
ZENITH - 000,001,004,023,038,058,059,064,073,121,135,136,153
Code for PROVIEW Television
There should be a list on the DISH network website.
Try this:
http://www.carltonbale.com/project/dish-network-universal-remote/
or
http://www.dishnetwork.com/content/faq/remotes/index.shtml
(this last one has links to remote control lists depending on the color of the buttons; around middle of page)
4helpful
2answers
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
2answers
RCA tv and a zenith remote cl015
take a poop ans sculpt it into a new remote.
Oh, i would let it dry out in the sun for a couple days before attempting to sculpt, up to you.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
