John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
Anonymous Posted on Mar 15, 2010
I need to rebuild a hydraulic cylinder on a john deere 4300 with a 420 front end loader. the cylinder is for the bucket. how do i disassemble it
  • Anonymous Mar 26, 2014
    how to remove shft cylinder
Wayne Fellows
Level 2:
  • Expert 262 Answers
  • Posted on Apr 07, 2010
Wayne Fellows
Expert
Level 2:
Answers
262
Questions
Helped
245977
Points
802
  1. This cylinder is not to hard to disassemble.
  2. Place upright in vise or suitable bracing.
  3. Using a block or dowel of wood(maybe rubber mallet also), depress the top cap of the cylinder to relieve tension on the ring.
  4. Use a small edged screw driver or pick and spin "retainer" in until the bent end comes to the opening.
  5. Lift up and rotate the ring more to allow the ring to pass over the edge of the opening.
  6. Once the retainer is started you can tap it with the wood and rubber mallet around the circumference of the cylinder to release the retainer from the groove.
  7. If you havent done so by now the oil should be drained.
  8. with the cylinder firm in vise(but not too firm to "distort the integrity of the cylinder.) Place the cylinder Sideways so you can pull out piston and rod assembly.*** Put hose or suitable drain on holes of cylinder***. With the motion of the piston the residual oil will tend to spray out.
  9. Pull on the piston and position it to bottom out on the top gland(cap) ie:full extension
  10. Place support under the rod to avoid damage. The gland is a tight tolerant fit with use of O-rings and backup rings. Too much offset can lead to damaging gland assembly, and jamming in the cylinder. You may be able to just hold with hand also depends on size, bore, stroke, pressure rating. Use due dilligence.
  11. Now that its out you have the piston assembly with gland in hand..**if only the rod comes out there are more steps to take, and you need a new rod but sometimes its more cost effective to buy a new cylinder. If there is a farm supplier or hydraulic dealer near they can certifiably /replace repair the cylinder for you. Hydraulic pressure is kind of like lightening. If it strikes you under pressure it can kill you.*** Using the dead blow or rubber mallet try to pop the gland out by using the piston/rod assembly as the puller. You may not have to remove the top clevice or other end of the cylinder, so maybe you could tap on that.
  12. The piston can be removed from the rod depending again on make. Usually a socket head cap screw or king nut holding it in place to the rod.
  13. When the piston is removed you should be able to slide gland off also.
  14. You'll need that pick and or the screwdriver to pick out the seals carefully. Let me know if you require more...WF Services
Anonymous
Level 3:
  • Master 468 Answers
  • Posted on Mar 16, 2010
Anonymous
Master
Level 3:
Answers
468
Questions
0
Helped
228233
Points
1496
You'll have to use a spanner type of wrench and unscrew the end of the cylinder. Once it screws out, the ram will come out, and you will have access to all the seals to replace them.
Testimonial: "a spanner wrench is needed but it's not threaded. a snap ring must be removed through a small hole in the side then it slides apart"
1helpful
I have a John deere 2320 compact tractor with a H130 front end loader. Bucket will not stay tilted downward when trying to scrape material down off a pile of snow or dirt. Any thoughts as to a fix
the return valve or tilt back control is allowing oil back and not locking the bucket in a set position so that when pressure is applied as in lifting ( moving backwards to smooth out) that oil in the cylinder is not held in check
check bucket controls and valves
Iv'e got a h120 john deere loader the bucket quit lifting it tilts etc.bad cylinders or what?
check the control valve for the lift operation. If it tilts then the hydraulic pump should be ok but if it is not lifting then then the pressure is not getting to the cylinders to push on the rams. Is there enough oil in the reservoir for the operation.
5helpful
System creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
2helpful
2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
