This is a projection tv correct?Yes?The old projection lamp has not been replaced like 1 1/2 or 2 years?Tv in used daily like 4 or 5 hours everydays?Yes?Tv make buzzing sound and bell sound on and off.The tv on the frame the word "LAMP" the LED light indication it is flashing or stay on lit?Yes?Then the tv projection lamp life have ended,tv require a new projection lamp.
I didn't look up the model to see if its a LCD or LED, if its an LED it sounds like you have some lamps going out, try turning down the backlight settings and see if that helps
Sounds like the lamp. Turn the TV off, unplug the TV from wall, wait for half hour. Remove the lamp and see, if it is fogy looking, this will give you an idea if the lamp is going bad.
It sounds Lamp is weak and causing darker picture. How old is this TV and did you replaced Lamp recently? If lamp has not been replaced in past 2-3 years then its time for new lamp, XL-2400 available in Sony Accessories Store and lamp replacement procedure is written in user manual. Thanks.
It sounds that lamp in TV is weak and not throwing enough light to bright the screen for good image. How old is this TV and did you replaced its Lamp recently? If lamp has not been replaced yet or in last 2-3 years, replace it.
The first time my lamp needed replaced, the red light came on as well. This time my tv did the same thing, but after talking to my tv repair man he thought it was the lamp. He said that if you use your tv often then the lamp probaly needs to be changed after two or three years. I replacedmy bulb and it corrected the problem and I MUCH BETTER PICTURE.
