well you sorta do need an sd card. the memory in the phone is so small that only about 8-9 maybe 10 songs would fit on it. I have an lg gr500f and i use the data cable to put music on my phone ( i have an sd card). I have borrowed my friends sd card and just coppied music from the card to my phone on my phone before i got an sd card or using the bluetooth function from my laptop or a friends phone.
1st - Place the SD card in the phone. 2nd - Adjust the setting to save Pictures, Video, Music to the SD card by going to Settings and tools > Memory > Save Options. 3rd. Remove the SD card from the phone and connect to PC. Now on the PC you will see the phone has created folders for you "Music". 4th - Drag your music files into the correct folders (ie music, pictures, etc). 5th Place SD card back in LG Envy 2 and enjoy the music.
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Usually you should be able to take the SD card out of your phone and put it in a universal card reader (around $30.00 cost) connected to you computers USB port. The SD card will come up as an external drive icon on your desktop. When you open the SD card icon on your desktop by clicking on it the contents of the card should be right there visable. Just drag whatever you don't want on the card off the card and into the trash. It should no longer be on the SD card when you reinsert it in your phone.
Instead of loading the music manager, click on file in the LG Suite box, and then click 'content'. This will connect without a problem (at least it did for me, despite music manager not working), and then drag and drop music from your pc files, onto your phone. Hope this helps.
use a cassette adapter. put the adapter in your car's cassette player and plug the wire into you garmin. when a command is made, it will play through your car's stereo, provided it is on the cassette mode. also, using the cassette adapter, you can play music from your nuvi if you have music loaded onto a sd card and placed in the nuvi's sd slot. the nuvi will interupt the music to give directions, then go back to playing music.
The juicebox has a built in video intro that plays when there is no media inserted; it's a cyclic clip from various cartoon network shows. In order to play a video, you have to insert a Juicebox Video cartridge into the player. To use the MP3 kit, you put the SD card holder into the Juicebox. install the Juicebox software on your computer, put the USB card reader in your computer, and insert the supplied SD card. put a music CD in your computer, use the juicebox ripping software to convert the CD music into 128kbit MP3's, put them into the SD card. then take the SD card, put it in your juicebox SD card adaptor, turn it on. music will come out.
This same thing happened to me recently. My reader seemed to stopped working after I accidentally dropped my phone at work. I tried everything from formatting it to trying different memory cards and nothing worked.
I manually added the music files on my 1gb SD card at first and figured I should do it again and it didn't work. I then synced my music through Windows Media Player but that still didn't do the trick.
The solution in the end was to take the SD card out of the phone, turn the phone off, put the SD card back in while the phone is off, turn the phone back on, and then update your library. If that doesn't work you may have a faulty reader that came with some of the phone when they first came out.
type 277634# * # (no spaces) click port setting click mass storage click mass storage remove go back to main screen and check again for memory if this doesnt work,take out memory card and try without the memory card.
