Samsung YP-K3 MP3 Player Logo
Posted on Mar 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Samsung Rogue with a 16gb micro sd card, but can't get more than 2.15gb of music on the player. When I try to add more music or sync it with Windows Media Player, it says error syncing or won't recognize what I add. I tried to use Samsung Studio 7, but even with updated drivers it won't recognize my phone. Please Help. Thanks.
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 11, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470148
Points
19564
Remove write protection from sd card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Why do i need a sd card in my km570 ?
You don't need one, but you might want one.
Your phone will operate perfectly well without one, but if you wish to use intensively many of the non-essential features like the camera, music player or to download games and other applications then you may wish to add a micro-SD card. Your phone already has a generous 4GB of internal memory, and when you have used all of that up you can, if you wish, add up to a further 16GB of memory via an optional micro-SD card.
I hope that my reply has been of assistance to you, please take a moment to rate my answer.
Micro Sd keeps saying it does not contain supported music files
May be mp3 u are playing on your cell is not supported i.e. bit rate is greater than your mobile supports.
2answers
Doesn't show mp3 files on micro sd card
You have to drag and drop only the MP3 files into the music folder. If you have them organized and in folder by artist, drag only the MP3s into the card's Music folder.
Having problems playing music frommy sandisk 4gb micro memory card on my motorola ve240 cell phone
I have a similar problem, the issue for me was windows media player was creating a folder called music on my sd card and uploading the music there during sync function. However, the phone only looks in the \my_music folder on the SD card. Sync your phone, then rename the newly created music folder to my_music and the player will work. Still looking for a permanent solution to this problem.
I want to put music on my moto ve240
you need a micro sd card once you place the card in the slot provided under ther battery.. Go to setting select USB make sure Mass stororage is selected.. after that you can add songs by bluetooth or if you have a motorola usb cord compatible to your version you can connect your computer to your phone and sync it to WMP or with the USB that comes with the micro sd to add music
Saving music on my micro sd..
well assuming you loaded music on your sd card:
to find it, just go to mystuff....
menu, mystuff, center button, it should load the mini sd right there. then all you have to do is click over right and file explore the mini sd. you should put music in the music file.
another option on the phone.....
go to att music
menu, upper left icon, center button, music player, it should find all files.
let me know how i can help some more
2helpful
6answers
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
19helpful
14answers
why cant i get my micro sd to show on my phone
3helpful
5answers
Samsung j600 mobile phone MP3 player not playing MP3's
If your music files are in a folder you cannot add them to play list, but if you have all your songs singly you can add them to your playlist, I had the same problem tonight with this phone, we added them individually no problem, this has worked but is a lenthly prosses, so far so good, not had a play about with them other than this, still to get them back as an album not yet done, Jackie
Any problems ring virgin, they were very helpful, SGH-J600 User guide not explained very well
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
