I don't know about your atomic sync problem. But here is how you can set the time zone:
Push the Time button once. This will change the Month/Day window to
Alarm 1. Push the up button until the desired time zone is reached. Push
the Time button twice more to return back to Month/Day display.
Fcd44372-3b52-4770-9db1-1027ebd2254b.pdf
In order to synch you need to do the following:
Pull the batteries and wait a few minutes. Put batteries back in - time will set to 8:00 (or possibly something different). Press the "leverage button" (just above an to the left of the time zone buttons) and the clock hands will spin. Release the leverage button when the correct time is reached. Supposedly, this new time will track correctly and keep accurate time. Check this article as well:
http://home.comcast.net/~mark.flint/instructions-spc364.html page which contains the full instructions for the Sharp Atomic Clock .
Please let me know if this does not help else please accept it.
Thank You for contacting Fixya.com
The picture isn't of this clock and this clock is digital and does not have hands, so this solution doesn't apply. Also, given that it may not have the capability of working properly since Congress decreed the earlier/later DST in 2007, it might be just as well to allow the clock to catch up on its own. Interestingly, the satellite sync has started working since I posted the problem. Maybe the cloud cover wasn't allowing it to work properly. That sometimes happens with my GPS. Ideas? Do you know where a manual for this
