I have not been able to find any instructions on their web site, so the only thing I can suggest is that you go to their web site and click on "find a retailer" and speak to them and ask them how to do it.
Try parsecent.com they can get the part or a substitute part, the keeper is not sold separately tho, you would have to buy a complete band...good luck :)
Pull out crown and turn counterclockwise..if hands wont move then you need to take to a reputabble jeweler to have repaired, you have either a set lever problem or there is rust in stem tube and wont allow it to turn...good luck :)
If you have your instruction manual it should tell you how to reset the chrono. i have the Luminox 8352 and it says to pull the crown out to the 3rd position. then press and hold both the start/stop and lap/reset buttons for a couple of seconds. you'll see the second hand rotate, then you can single click the start/stop button to manually move the second hand 1 second, or you can hold it and it will continue move for a longer period until time desired. if you need to adjust the other chrono hands, click the lap/reset button and then you can click the start/stop button again. repeat for the minute/hour chrono hand. when you're finished push the crown back in. it might work even though it's a different model, worth a shot? hope that helps. these are really great watches.
Because of the way they work, it's quite hard for quartz movements to run consistently slow - so if you find one getting behind, it's usually a sign that it's stopping intermittently.
It would do no harm to check that the crown is properly pushed in after you've reset it, but my guess is that the watch will benefit from a new battery.
A.
