I have a singer 5040c and sometimes the tensioner works an some others not i think my roommate try to fix it and put the parts in diferent position. Did you have a diagram?.
My Singer Stylist 9100 has constant problems
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Instruction Manuals
Upper, it is your bobbin threading, lower bunching of thread it your top threading . Try this test, with the presser foot up, pull your top thread, with the presser foot down, pull thread again, it should barely move.
It is always the opposite of what you think, so rethread and do the test; Sometimes this little test will seat the thread in the tension discs better. I keep my tension on about 3 for most sewing, my other machines I use auto. I hope this helps you.
Do you have your manual? Because it is almost always the top threading, either tangled thread or a bent or dull needle causing the problem. You can download your manual at www.singerco.com for free and enlarge the detail of the diagrams for threading. I just hope that it is something simple and not your timing because that is not a do it yourself job, unfortunately. You can also call Singer customer service at 1-800-4singer. and get their advice. Good luck.
I have the same problem. Driving me nuts. The tension dial is broken, as far as I can tell. Just craps out from time to time. Sometimes turning it on and off helps. I personally think it's a problem with the electronic controls.
