Cannot set time on TGHK watch. No brand name on watch.Purchased at WalMart - no help. Unsuccessful searches on popular watch sites. Solutions posted on FixYa did not work.
As there are no possible watch manuals for unknown brands, all I can say is:Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Go through all and you will find the right one, as all watches stand on globally accepted basics. It may take some time, but at the very end you will get what you want.Rate me, please
On my son's watch, which sounds like yours, Mode is bottom left, Reset is bottom right, Start/Stop is top right, and the light is on the top left. Hope this help you!!
Here's the procedure:
Press the MODE switch to step through the modes until you see the seconds blinking (righter after the ALARM set mode).
Press the RESET switch to advance to the function you want to change (e.g. hours).
Press the START switch to increment the hour to the correct time.
Press the RESET switch to advance to minutes and, again, increment the setting using the START switch.
(Hold the switch down to advance the numbers rapidly.)
When you have stepped through all the elements and have everything as you want it, press the MODE switch once to return to normal time display.
To set the ALARM:
Press the MODE switch to display the alarm function.
Press RESET once to see the hours blinking.
Press the START/STOP switch to advance to the desired hour.
Press RESET to advance to the minutes and set the minutes using the START/STOP switch.
Press the RE#SET switch. The time will stop blinking.
Set the alarm sound for either ALARM or CHIME using the START/STOP switch.
Press MODE to return to the time display.
To turn the ALARM off:
Press the MODE switch to advance to the alarm mode.
Next to the AL indicator there will be either a small ALM or CHI displayed. Press the START/STOP switch until they both are off.
This isn't helpful seeing that none of the 4 available buttons are labeled. No way to tell which is MODE, RESET, START ect. Any direction there?
Thanks patw28; these instructions are prefect. JoeA: MODE is at 2:00; RESET at 4:00; START at 8:00; LIGHT at 10:00
