Efficient Networks SpeedStream 5667 Modem Logo
Posted on Mar 15, 2010
I bought a new-in-box speedstream 5667 modem from a private party. I found instructions on the internet for configuring it, but I can't connect to the http address given for doing the configuration. How can I configure it with my user name and password? (the address was 192.168.254.254)
I need the usb driver for the 5667 for xp
Here's what I found:
http://www.dslreports.com/faq/16029
Hope it helps!
I'm trying to install and configure my TrenDnet router but first I had to set my modem to bridge mode to use the router but when in bridge mode my SpeedStream won't connect to the internet. Why?
In Bridge mod, it means that you have to configure a Broadband connection on your computer to be able to connect to the internet.
To use your router with the speedstream, the Trendnet must not be used in bridge mode. Configure it to be connected to internet, then plug the speedstream to it.
1helpful
Ethernet light flashing
Check your DSL Filters on your house phones or anything connected to the phone line EXCEPT the modem. The modem should not have a filter on it. If this doesnt help I would recommend getting your ISP out to test the line because sometimes the resisitors or hardware in the box goes bad or at the DSLAM.
3helpful
How do i make my speedstream 6520 wireless?
"If your PC has not been connected to a broadband modem or other network device, you will need to
perform the PC configuration procedure below. Remember to restart each PC when finished. If your
PC has been connected to a broadband modem or other network device, continue to the “Using the
Wireless Connection” section below.
1. Start your Web browser. In the Address box, enter the following: »speedstream.
2. Press Enter. The SpeedStream Simple Setup Wizard will launch.
3. When prompted, enter the Internet connection information provided by your
Internet Service Provider.
4. At the end of the Setup Wizard, you will be given the option to either connect to
the Internet or further configure the optional settings of the gateway.
5. If additional configuration is desired, select the icon for the service or option
you wish to configure: the gateway’s firewall and security settings, User
Profiles and content filtering, or home network options."
"Using the Wireless Connection
By default, the SpeedStream® Gateway is configured to work
seamlessly with other SpeedStream® wireless products. The default
wireless interface settings are:
SSID: SpeedStream
Channel: 11
Mismatched wireless settings will prevent successful
wireless network connections between devices, so
you may need to reconfigure some wireless settings
to ensure that all settings match between wireless
devices if you are:
a) Using another manufacturer’s wireless products
b) Adding the SpeedStream® Gateway to an existing
wireless network
The Setup Wizard will walk you through setting up wireless settings."
Speedstream 5667 Ethernet ADSL Modem
My guess may be you are looking for Telephone cable which you need to connect it to a wall outlet for internet line. You can purchase it any hardware shop or at an electronic shop.
Thanks.
2answers
I just bought a SpeedStream 4100 modem
if you brought the wireless new from a vendor. you don't need to configure it. unless you want to.
but if you brought a used one (in you case). you have to configure it. You need to get inside (software wise) of the modem. to do that you need login name and password to start with. if you don't have it, please call or e-mail the guy you brought the modem from.
then you have to configure the security for the wireless, unless you want everyone under sun to access your modem via wireless.
search on the web, you should come away with a user manual for the unit.
Will not connect
First, I would make sure you are using the right type of patch cable to connect to your cable/dsl modem. There are two types: 1) Straight through 2) Cross over The manual for this device says to use #1 when connecting directly to a computer, and #2 when connecting to a hub. http://www.fltg.net/Software/5667B%20Quick%20Start%20Guide.pdf If the cable/dsl modem is powered on and you are not receiving a link light on either the cable/dsl modem or your computer, try using a different cable. If this does not work, then you may have a problem with the device itself. At that point, call your Internet Service Provider, as they may be able to provide you with a replacement. If you did not receive this device from an ISP, then you will have to contact the manufacturer directly. Unfortunately, it looks like Efficient Networks was bought by Siemens, so you may have a hard time receiving support from them. http://www.efficient.com/ http://subscriber.communications.siemens.com/broadband_family_frame.htm
ISP SBC SpeedStream 5100b Modem Causes Install and Connection to Fail
Symptoms * You have a new router, and cannot get online to the Internet. AND * The Setupwizard will detect dynamic IP even though you have a PPoE connection. (Going to router status on the administration page, there is a private IP address on Internet port. 192.168.x.x range.) Cause The SBC DSL modem SpeedStream 5100b, used on new DSL and Yahoo SBC DSL installations since Feb. 2004, causes the NETGEAR router Setup Wizards to fail, and prevents routers from connecting to the Internet. This problem affects many router brands. The modem can be distinguished from the earlier 5100 by a 5th light labeled "Internet". The SpeedStream 5100b's default configuration is "PPPoE on the Modem" ? matching a built-in PPPoE client convenience feature that sends login ID and password to SBC. To Work Around These Issues, Configure the Modem for Bridged Mode Note: In Bridge Mode you cannot to connect to the modem's configuration menu, except by resetting it as described below. 1. Disconnect the router from your network, and connect the computer directly to the SpeedStream modem 2. Open an Internet browser. 3. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 4. Click Advanced. 5. Enter the "Access Code" printed on the bottom of the modem. 6. Click PPP Location. The PPP Location screen appears. 7. Select Bridged Mode (PPPoE is Not Used). 8. Click Save Changes. 9. Connect the router between the computer and the modem. 10. Power off the modem. 11. Power off the computer. 12. Connect the Internet port of the NETGEAR router to the Ethernet port of the modem. 13. Connect the computer to a LAN port on the NETGEAR router. 14. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 15. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 16. Power on the computer. 17. Log in to the router by typing 192.168.0.1 in your browser. 18. When prompted, using lowercase letters, type admin for the user name, and password for the password. Some older routers use 1234 for the default password. If you forgot your router password see http://www.fixya.com/ThreadView.aspx?thid=102081&prdid=252188 19. Use the Setup Wizard to connect to the Internet. To Reset the Modem To Enable Access to the Configuration Screen 1. Disconnect the computer from the modem. 2. Power off the modem. 3. Power off the computer. 4. Connect the Ethernet port of the modem to the computer Ethernet port. 5. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 6. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 7. Power on the computer. 8. Open an Internet browser. 9. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 10. Click Advanced. 11. Enter the "Access Code" printed on the bottom of the modem. 12. Click PPP Location. The PPP Location screen appears. 13. Select PPPoE on the modem. 14. Click Save Changes. 15. At the login screen type in your SBC member ID and password (which is usually the primary email address on the SBC DSL account and the password for the primary email address). 16. Click Connect. * If successful, a screen appears reading "You Are Connected", and the Internet light goes solid green. * An error will display if the username or password is invalid. * If there are other problems the message "The DSL connection is down" appears.
Top Efficient Networks Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
