Televison & Video Logo
Posted on Mar 15, 2010
I need a new screen protector for my older RCA big screen TV
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
155
Points
I have a screen protector from a 1998 RCA older model big box style tv
RCA TV older big back 36" went out during power outage storm, back on with good volume but pictur only a thin line in middle of screen across
People are giving away their older TV's as they upgrade to new wide flat-screens nowadays. That makes your TV not worth fixing. Keep checking Craigslist and your local thrift stores for one that's cheap or being given away.
I have an older model rca rear projection tv. The problem with the tv is that the picture bends into curve after about 5 minutes after it has been turned on. Please help.
Check the convergence IC's for cold solders, check for leaking capacitors in the area. Check the voltage regulator with a Variac.
Usually these sets just need the 2 big convergence IC's replaced with new ones. Clean all 3 picture tube lenses, mirror and screen. Get the original RCA remote that came with the set and MANUALLY align the convergence.
Rarely the bow on the bottom of the screen is not repairable.
We have a big screen rca tv , one of the older models, it has worked fine up until now. The picture is stretched out and we can't even see what channel we want to watch on the guide it need to come in on...
this problem is connected with your horizontal control. if you can bring it to your tv repairman and see if the horizontal board can be repaired or replaced this is what i have found on many older models due to heat build up in the case.
2answers
Mitsubushi Big Screen TV Screen Protector vs 60601
that will have to be a dealer orderd item.. Unless you can find one used. I would try the tv shops in your area , they may have a used mitsubishi screen
5helpful
4answers
Cracked plasma tv screen
I had one broken a few months ago. I got a couple quotes.. it was about $200 less then a brand new one. I'd just buy a new one.
For the new TV I'd pickup a screen protector for it. My son threw a toy at my TV the other day and I nearly had a heart attack from the flashbacks. Thank God I picked up one of these a few weeks earlier. It stopped it. http://www.tv-armor.com
Mike
2helpful
4answers
Rca tv
my son cracked our screen protector and instead of paying two or three hundred dollars to replace it we had plexy glass cut at Lowes and put velcro striping around the edges and looked as good as the original and has held up great for five years now.
1helpful
Tv wont turn on
you have defective horizontal output replace a new one H out.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
