Sebo X4 Bagged Upright Vacuum Logo
Posted on Mar 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I fit the foot pedal back on on a SEBO
Anonymous
Level 3:
President:
  • Master 389 Answers
  • Posted on Mar 15, 2010
Anonymous
Master
Level 3:
President:
Answers
389
Questions
Helped
247269
Points
1343
This is much easier to do than to describe! Your question suggests that you plan to re-fit the same pedal that has come off, so first you need to be sure that nothing actually broke when it came off. You should be able to clip the plastic part back on to the metal part - it should stay there and not fall off (if it falls off, you need a new one). The trick is to get the flat metal part correctly located in the plastic part, so with the plastic part not clipped on, pull the metal part down and rest it in the plastic part, then push the plastic part in to position. The flat metal part should then be trapped behind two projections on the plastic part, so that there is some movement, but not much. These projections may possibly have worn away, allowing the pedal to come away in the first place, in which case you will need a new piece.
I hope this helps. If so, please remember to rate this response as I value feedback. If you need more help, just post a reply here and I'll get back to you as soon as I can. Good luck!
  • Elle Aitch
    Elle Aitch Apr 14, 2022
    Really helpful plus I used the picture from HomePro Vacuum. All mended now and I'm very grateful. Thank you
The pedal on my hoover is stuck
Your foot pedal is likely not snapped on to the axle assembly all of the way.
1helpful
A picture of how to replace foot pedal
This is what your foot pedal should look like installed 25164187-2lznyozag1oxf2xdn4xr045t-3-0.jpg
How do I remove the swivel neck assembly from the vacuum case?
You will also need to remove the screws on the inside that hold the motor in place because part of the side support for the swivel is under the motor. Remember to disconnect wires coming from the swivel as well before you try to pull it out, so that you do not damage them. Hope this helps.
Sebo upright foot peddle came off how do I attach it back
yes but you will need a new spring to put on it or you can leave it off it will not harm anything it just will stop the vacuum from standing on its own so yes
How do you cheng the filter
The Sebo X1 has 2 filters. Both should be changed once for every 20 bag changes. The long cylindrical filter in the bag compartment just slides out to the front - grab the little handle at the bottom and pull forwards - it can be a bit stuck, so you may need to lever it out with a screwdriver or similar. When you put the new one in, make sure you push the little metal lever back up behind it (this is just a simple device to prevent you from shutting the bag compartment when there's no filter present).
To find the second filter, release the foot pedal and lie the handle flat on the floor. This exposes a square panel with lots of small holes in it. Release that panel by squeezing the clip, lift it off and pull the foam filter out. Just drop the new one in and replace the cover, pushing it until it clicks into place. Job done!
I have many SEBO automatic X4 vacuums with broken foot pedals. I would like to buy 5 foot pedals that I believe the part number is 5059DG can you tell me where to get it
I guess that depends where you live... plenty of spares sources online (google sebo vacuum spares)... otherwise google sebo dealerships in your country/locality.
1helpful
The Clog light is on my Sebo Essential G1 vacuum
If you are sure the base is clear, and that the flexible hose and attachment tube are clear, the only other common place for a blockage is the swivel neck that joins the base to the bottom of the dust bag housing.  Here's what to do:
Press the housing release button (front bottom of bag housing) and lift off the bag housing from the base. This can be quite hard (three or four hands would be helpful) but be sure to lift straight. When you've got the bag housing off, release the foot pedal and lower the swivel neck to 45 degrees.  Check inside the swivel neck channel closest to the foot pedal, and clean it out as necessary.
If this doesn't work, please post again and I'll see what else I can do...  If it does help, please rate me!
Top Sebo Vacuums Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
