Obtaining Huffy Mt Havoc 10 speed index all terrain series bike manuel
SOURCE: operator manual for huffy crosswind bike grip shift
Look for the manufacturers name and model number on the gripshift and check at www.parktool.com. Look under derailleurs for repair tips which will give you an idea how they work. A twelve speed has six gears on the rear sprocket and two on the crank giving you a combination of twelve speeds. sheldonbrown.com is another good site with good articles and pictures.
SOURCE: I am trying to fix
You can use the 6 speed rear derailleur with no problems. The 5-spd shifter does not need to be disabled, as it will work just fine.
The shifter controls the rear derailleur, telling it how far to move. The rear derailluer just follows what is dictated, so there is no real difference mechanically between the 5spd and 6spd derailleurs, only in the shifter.
If you wanted to make the bike 6spd, you would have to change the shifter and gears along with the derailleur.
SOURCE: using a Huffy Verona Comfort Series bike - how do
The same way they all shift (considering the different physical designs of the shifters). Each lever has a control for INcreasing required effort or DEcreasing it. They work opposite each other.
Get on a search engine and look for "how do you shift gears on a bike" for many videos.
Huffy has manuals, too.
http://www.huffy.com/Support/OwnersManuals.aspx
SOURCE: Just bought a Roadmaster Mt
Take those first two questions and plug them into a search engine and you will be rewarded with instant answers and videos.
Last question: not just forward motion, pedaling
