Change the battery in the remote, then reprogram the remote, {key fob}activator inside door making any sound? If so, the connection is working, just not sending the correct signal.
Key fob has a dead battery does the remote open an close side doors remote door lock work if not probably dead battery in remote also if battery was changed may have to reprogram remote system
that would have to be done by dealership they have to go into the program an relaern the remote
just replace your battery you have a central control module, that stays programmed, the only way you need to get it reprogrammed is if you take it out and put it in another car
You should not have to reprogram the remote if you are just changing the battery. I would first check to make sure you put the battery in correct side up. If that didn't work try disconnecting both terminals on your car battery for 10 minutes. Then reconnect them and try your key fob. This has worked for many people and I have no idea why.
If you have the original remote, it does not need any reprogramming because the Sony code will be the first one even if you change the batteries.
Try pressing the TV key on it if you have the RM-Y185 remote, also try to move the switch to the AV1 position.
