HOW TO SET THE TIME KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( usaully default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
SOURCE: CHANGING THE TIME ON PHONE
I can give you the fast answer and the slow answer. Fast one is to go to the main phone, press PROG and dial **1234. The system should go into programming and you will be looking at system program 000. ENTER. From there, using a combination of the SEL, FWD and CONF keys, you should be able to navigate around the time change, using ENTER or STORE to save it.
The arder way is to grab the manual here http://www.public.carl.airpost.net/TDA/TDA_PTPM_32.pdf and start reading it from page 12 then follow the instructions on page 16.
Keep in mind that TDA programming is usually done from the master phone, or any phone assigned programming status. It may be all or NONE.
Carl
