1997 Chevrolet Lumina Logo
Anonymous Posted on Mar 13, 2010
The brake lights wont work. The brake light over
The brake lights wont work. The brake light over the window works but the tail light brake lights wont work. 1997 chevy Lumina
Anonymous
Level 2:
  • Expert 306 Answers
  • Posted on Mar 13, 2010
Anonymous
Expert
Level 2:
Answers
306
Questions
0
Helped
103458
Points
907
The break light wire on the lumina runs through the blinker switch or multifunction switch on the colum.. check there as well as at the tail light sockets. on the late 90s gm cars the sockets had a tendancy to rot away... use a test light at the brake light wire in the trunk and have a friend apply the break. if there is power then may have to get new tail lights. or replacement bulbs.
Testimonial: "THANKS FOR THE HELP"
2 Related Answers
Andrew
  • 63 Answers
  • Posted on Nov 22, 2011
SOURCE: 1997 Chevy Lumina REAR BRAKE LIGHTS DONT WORK
This will either be a fuse or the brake light switch which is on the pedal it's self. More likely the switch as these are fickle at best.
Anonymous
  • 141 Answers
  • Posted on Jan 20, 2009
SOURCE: Brake Light Problem -1997 Chevy Lumina
The ground wire in the trunk area, coming from the brake light harness, might have come off or really loose. Hope this will get your lights working again. Best wishes.
1989 Honda accord tail lights wont work
Tail lights consist of running lights, brake lights, turn signals and backup lights (also tag light). Which of yours are not working?
2answers
Brake lights are not working but my back window brake light works and so do my tail lights and turn signals. 01 chevy malibu
if rear window stop light works has blown globes in other 2 tail and stop are different circuts fit 2 new globes only go in 1 way
Tail light wont come on
Look for short in wiring within the wiring harness. Had same problem and found 2 wires shorted together
Tail lights always on even when engine is off, and rear brake light wont come on
The tail lights dont have anything to do with the engine running or not.. you mean the brake lights are on? all the time? all of them, or just the one in the back window? If the back window brake light doest work the bulb is bad. If the brake lights stay on, the switch may be bad, out of adjustment, or the bumper for the switch fell out/broken.
Brake lights wont work right tail light wont work 2003 gmc envoy
check globes and check brake light switch under dash on brake pedal.
2helpful
Tail break lights don't work. Window break light does work however. Bulbs have been replaced.
Check the brake light fuse. The high mounted brake light (third brake light) is on a different circuit than the brake lights. Hope this helps.
3helpful
2answers
Right brake light out; tail light works fine
most rear tail lights and turn/stop lights are the same dual filiment bulb. it is possible for your tail light to work and your brake light not to and still have a bad bulb. I would check the bulb first, your brake light works on the left yes? this would mean that the fuse is fine
2answers
Tail lights wont work
sounds like ground problem- remove tail lights and look for wires going to body -remove screww clean grounding area and replace- both sides. You did not say whether the lights work when car is off? With car off and brake pedal pushed is there any brake lights ? If not procede with above.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
