Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher Logo
Posted on Mar 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Bosch Exxcel dishwasher wont clean properly?
My dishwasher wont clean dishes, pans or cutlery properly on any cycle (the machine is never overloaded). The machine is 6yrs old and I was wondering if there are any cleaning problems associated with this particular model (Bosch Exxcel Multi Program)
Thanks!
Anonymous
Level 2:
  • Expert 457 Answers
  • Posted on Mar 13, 2010
Anonymous
Expert
Level 2:
Answers
457
Questions
Helped
126665
Points
799
The cleaning section is mostly from the circulation pump. is the pump is not working it has to be replaced .go to sears partsdirect.com and check out part first,. this will let you know the prices to fix or replace. then call ten repair person and find the cost to change the circulation pump.
Bosch Dishwasher SHE43C cycle takes too long
Domestic dishwashers work by taking cold water and soaking the dishes as the water warms. Then it gives a good wash at high pressure, drains, refills, rinses and then hot rinses to dry.
If it is slow because of slow filling, check the water pressure and also clean the strainer filters on the supply hoses where they go into the machine.
If you want speed, buy a small under-counter commercial machine. They fill with hot water, have a tank heater and a rinse tank heater and the whole cycle is 3 1/2 minutes. Glasses first, plates and cutlery next, and pots and pans last.
Seems to be a known issue!! Videos here with solutions
https://www.google.com/search?q=Bosch+Dishwasher+SHE43C+cycle+takes+too+long
Where can i get a bottom tray for a nobel dishwasher NBFS4 S/S model
nobel dishwasher cutlery tray - Compare Cheap ... - GetPrice
www.getprice.com.au/buy-best-nobel-dishwasher-cutlery-tray_pn9.htm
Results 321 - 342 of 342 - Compare Nobel dishwasher cutlery tray price and readNobel dishwasher cutlery tray reviews before you buy. ... Bottom... more info.
I have a Nobel Dishwasher, model NBFSDEC. I have ... - Fixya
www.fixya.com/support/t24625480-nobel_dishwasher_model_nbfsdec
Jun 13, 2014 - I have a Nobel Dishwasher, model NBFSDEC. I have cleaned the filters ... Dirt left on dishes on top tray; bottom tray washes fine. Apr 03, 2009 ' ...
Household Cleaning Urban Myths: Do They Actually Work ...
www.apartmenttherapy.com/household-cleaning-urb...
Apartment TherapyJan 31, 2011 - com1Line the bottom of a pan with aluminum foil with the shiny side up. .... To get baked-on crud off of broiler pans, oven racks, roasting pans, glass baking .... Burnt pans, if you don't believe in Easy Off (a Nobel Prize for the ...
dishwasher in Scarborough, WA ' Dishwashers ' Gumtree ...
www.gumtree.com.au > Home & Garden
Jan 04, 2016 • Dishwashers
Glasses and frying pans not clean at end of cycle. Residue on glasses and cups,food particles on frying pans.
it's generally not a good idea to put really greasy items in a dishwasher along with relatively clean items such as glassware and plates and cutlery, as most recent good quality dishwashers come with a soil sensor that ends the wash cycle once the dishes appear clean, and all the grease from your frying pan will cause the soil sensor to take longer to detect clean water.
Jun 29, 2011 • Dishwashers
1helpful
2answers
Dirty dishes & not draining properly
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
I have the same problem with mold in the dishwasher and Bosch is much less than helpful to solve the problem. I will never buy Bosch again.
try running the unit with 1/2 cup of bleach without any dishes in the washer this shold kill the mold and once the cycle has completed there wont be any bleach in the dishwasher but run it a couple of times empty to ensure the bleach has done its job
16helpful
2answers
5helpful
I think my Bosch dishwasher might be a "lemon". I
Don't be afraid now, but , what I'n going to tell you works VERY often. Pour two cups of bleach into the washer and let it run a potscrubber cycle. They do this all the time at restaraunts, yes really! Let me know how this turns out. P.S. leave the machine empty when you run it. Thanks, Dana
Cutlery is cloudy and dirty, some food is dried onto knives and forks. Cups and glasses are cloudy and not clean on inside. Coffee or tea stains are not removed. Plates and soup bowls seem OK , and water...
they must have changed the way they treat the water in your area. those spots are caused by hard water. www.dishwasherfilter.com has a product out for this problem. it filters the water going into your dishwasher leaving them spot free and crystal clear with every load. you will love the way your dishes look.
1helpful
Bosch Exxcel Dishwasher
no not if it getting hot it still sounds like the motor isnt coming on put the spray arms in the same position turn it on then open the door are the arms still in the same position or haved the moved.those cleaners need hot moving water to melt the seal.
Aug 30, 2008 • Dishwashers
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
