Tomtom ONE 3rd Edition GPS Logo
Posted on Mar 13, 2010
How do i reset my tom tom one new version - Tomtom ONE 3rd Edition GPS
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
220
Points
How do i reset my Tom Tom One. green light on and charged top switch does nothing?
2answers
Cannot reset Tom Tom ONE 130. Have held down power button to no avail. Used only 2 times. Battery charged
There is a small hole near the docking base , insert a pin to reset the unit. Holding down the power button will never reset the unit.
Hope this helps. thanks
1helpful
I have the Tom Tom ONE (Build 2000) Tom Tom Palermo (if this Info Screen info is helpful). This Tom Tom HAS NO RESET PIN HOLE (Thanks a lot Tom Tom). I instaled included Tom Tom Home software, went to...
My thanks to the gentleman who posted the link to Tom Tom's solutions link. Although I had been there previously months ago when I first encountered this problem, there had been at that time, no instructions from them on how to properly reset the One that does not have a reset pin hole. That was in March. There are now such instructions.
The key to resetting such a Tom Tom GPS device lies in plugging your One into your computer, which automatically launches Tom Tom Home software (please remember, you have to have Home software installed on your computer already). After doing this:
1. When Home launches, go to Manage My Device Folder (p.2) and click it to open it.
2. You will see a folder-style window which lists all of the items that are your device. Select the folder tab: 'Items on device.' Then Deselect Applications. Click OK when promted. The Applications software will be deleted from your Tom Tom One.
3. IMPORTANT! Then clcik the other folder tab 'Items on computer.' Do the same here by deselcting to uninstal software on your computer as well. Click OK when promted.
4. If you do not get an automatic dialog box indicating that you need new application software installed, return to p.1 and select the folder 'Update My Device.' Follow the instructions as prompted and Tom Tom will both download new computer Home software as well as new software to the One device.
That should do it.
I will tell you that it took me three passes at this process. So it's not a breeze. But in the end it finally worked. And my One, which had been down since March is once again finally up and running with new software and as well as I remember it working.
Hope this helps others.
Tom
Tom Tom Go 730
trying to find how to got pin tom tom go 730
Tom tom will not switch on
try charging the tom tom fully and then reset while it is charging. a tom tom will not reset unless the new battery is fully charged which may take some time if you only have a car charger.
please give me a fixya! rating if this helped.
5helpful
4answers
How do I reset to factory settings how to reset factory settings on tom tom one
Which Model of Tom Tom One ?
XL
3rd Edition
2nd Edition
make sure you're fully charged, remove any optional memory cards (depends on the unit) there should be a reset hole, place a straightened paperclip into the hole and press for 15 seconds.
140/130/125
make sure you're fuly charged, press and hold the on/off button for about 15 seconds until the unit restarts
1helpful
Tom tom home does not see my tom tom go 520
Hi canal_boat_m
Try this solution:
STEP 1 Un-install Tom Tom Home from your PC
STEP 2 Click on the link below:
http://tomtom.com/lib/img/cs/S4S/files/RemoveRegEntries_TTGOv1.exe
This will download a little removal program for the Tom Tom Home program.
A Black window will appear briefly then close.
• Make sure that you have got Administrator rights on the PC. Otherwise you may not be allowed to connect new hardware (especially the case when using office computers)
• Reboot your PC
STEP 3 Visit Tom Tom website and download the current new version of Tom Tom Home and install it to your PC
STEP 4 Connect the TomTom
• Make sure the device is fully charged before connecting it to the computer. Ideally a mininum of 4 hours charge.
• Reset the device using a paper clip (see http://www.tomtom.com/6965). When resetting, keep the reset button pushed in for at least 20 seconds, but DO NOT turn the device back on just yet.
• Ensure that your TomTom has power connected to it. There should be a green light on the TomTom unit. If your device came with a Home Charger, please make sure that is plugged in to the TomTom also.
Your Tom Tom should ask you to 'Connect to Computer' if it does tap YES.
SOLUTION:
Your unit should now be recognized by your PC.
IF IT DOESN'T then follow the instructions below:
1. Connect your unit to your PC;
2. Copy two folders to your PC (namely 'Raster' and the one which holds all your maps - probably called 'United Kingdom and Eire';
3. Using Windows Utility, right click on the Tom Tom drive unit and select Fomat;
4. Switch off the unit and soft-reset it with a paper clip (but hold it in for at least 20 mins) and then re-connect it and power it up;
5. Tom Tom Home should now detect the unit and your unit should ask you to 'Connect to Computer' so tap YES;
6. Tom Tom Home will now say your device needs updating - and if you apply all the changes it will restore it to Factory Finished!
7. Then all's needed is to replace the two folders you backed up and any other items like mp3's and sounds, pics, etc.
Tom Tom 910
Complain to Tom Tom ,you may have a lemon,look for law suit soon
TOM TOM WON'T NAVIGATE
Reset your device
Reset your TomTom using a straightened paper clip.
If you use a PDA, check the manual that came with your PDA to see how to reset it.
Install the latest application
We recommend always having the latest version of our application installed on your device.
See also: How to check for and install an updated version of the TomTom application?
Tom tom one
okay found the solution. Shipped with outdated software. Had to use tomtom home to get the new version of software and gpsquickfix and now it works fine. No resets. Can turn it off and now I am getting all it is finding all satellites.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
