The timer doesn't work. The dryer just runs until you turn it off by hand or open the door.
Is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Testimonial: "I've already located and ordered a new timer. Thanks for the quick response."
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
SOURCE: dryer wouldn't shut off except with door open, now it won't run
More than likely the cycle timer is bad. Have it replaced and that should put you back in business. Hope this helps. Please re-post with up dates. Good luck. Thanks cj2176.
SOURCE: timer is slow or sticks. and dryer keeps running
Sounds like you need as new timer motor. They often get gummed up and slow down or become inoperable. Check with a local dealer or repair shop for particular model.
