When playing all DVD's, I can not hear the voices. It is like a muffled sound, but the music and back ground noise plays. The weirdest thing is that the sound plays with other languages. Can you please tell me how to fix the problem?
First check the settings on the audio menu of the dvd player. make sur it is set to 5.1 (if available) otherwise set it to stereo and your system should decode it.
assuming the second step is okay : as other dvd you play seem to work) it still may be that your unit is decoding stereo inputs just fine and 5.1 is not working properly....
so if adjusting audio settings in dvd play back menu dont work,
check that the cables to the satellite speakers are connected correctly and all plugged in soundly ( voice is high frequency,- coming from satellites - the garbled noises you hear are the base ( low freq) elements of voice which are coming from the bass box ( that the X.1 part of 5.1) and so that is obviously working. ,
I have to differ with the above content. Voice content frequencies are closer to 80htz - 4Khtz. Secondly, none of the other speakers are of issue, not the front left and right, not the rear left and right, nor the sub. The only speaker that is affected in your case, is the single center speaker. I would try the factory reset in your owner's manual. That should correct this. I would say that you might have a bad center channel, but you say that it plays in other languages just fine. Try the reset...
I have the same problem. I can not get it to work
when im playing dvd no voice is coming,only music
Same problem. I run it through a new Sony AV receiver but I only have 2
speakers hooked up. Would it be on the Sony Blue Ray player that you
adjust the settings or can/should it be done on the AV receiver?
Have an internal Blue-Ray Disk (LG GGC-H20), the SECOND one I've installed (the first was Lite-On). While I can get 5.1 audio fine through my speakers from other devices, a DVD will play background and sub-woofer channels, but NO VOICE (at least from the main characters -- background conversation comes through fine). Updated drivers, checked plugs, ran tests -- works fine, even from other SATA devices (e.g. HDD). Suggestions?
I have a samsung home cinema for a few months now and I find it very nice and easy to operate. During the last 2 days I had the same problem, no voice just music. I visited this site in order to find out how to solve the problem before I contact the sales company.
After going through the manual I found out that the music is distributed by the peripheral speakers but the voice is only coming from the center.
I run a sound test and realised that NO sound was coming out from the center speaker. I checked the cables and found one of them disconnected. Put it back in. Problem solved. Maybe this is helpful for someone.....Cheers
