Vtech Cordless 6041 Phone Logo
Posted on Mar 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Caller i.d. doesn't work piece of junk - Vtech Cordless 6041 Phone
Anonymous
Level 2:
Guru:
  • Expert 324 Answers
  • Posted on Mar 13, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
324
Questions
Helped
117603
Points
939
Please download this manual, and study e.g on page 21 About caller ID If you subscribe to caller ID service from your local telephone company, this feature displays the name and telephone number of the caller before answering a call (even when you are on another call). The caller ID features of this product will work only if you subscribe to caller ID service and both you and the caller are in areas offering caller ID service, and if both telephone companies use compatible equipment. Contact your local telephone company if: • you have both caller ID and call waiting, but as separate services (you may need combined service), • you have only caller ID service, or only call waiting service, • you do not subscribe to caller ID or call waiting services but wish to try them. There may be fees for these services, and they may not be available in all areas. This product can be used without subscribing to either caller ID or combined caller ID with call waiting service, although the caller ID features of this product will not function.
http://www.vtechphones.com/docMgt/public/art/52882/6041_manual.i4.pdf
muhrukhsaeed
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 15, 2012
muhrukhsaeed
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4213
Points
I want need on my number incoming and out going call details
3helpful
2answers
Caller id is not working in my cordless phone. Instead of number of a caller, "Incoming Call" is showing. Please help me
Caller ID on landline phones relies on signals from the telephone service provider. Some companies charge extra if you wish to enable the service, others include it automatically, so you need to check with them first.
Even if you have caller ID enabled, callers can choose to withhold their number. Large companies which make lots of outgoing calls (especially cold callers) often have their service set to automatically withhold their number. In many countries, all other callers can choose to do so by prefixing all dialled numbers with a short code, e.g. in the UK it's 141. Mobile phone callers can usually alter a setting on their handset so that caller ID is withheld when making outgoing calls.
My caller ID speaker doesn't work.
hi this is uday i thik your phone cells is ded change new 3.3 pen cells, or Speaker is not working change spekar in side thank you byyyyy
Caller id doesn't work for iphone 4
Caller ID is a staple in every iPhone. Your service provider may have blocked your Caller ID, so make sure to check with them first. To check if your iPhone has enabled the Caller ID setting:
1. Go to settings.
2. Click on Phone.
3. Click on Show my Caller ID, and select Yes.
7helpful
2answers
When my Motorola H720 is plugged in, the red light is flashing quickly, what could be wrong with this? It does not seem to turn on either....problems?
Red light flashes when I try to charge it and nothing all other times. Doesn't turn on, doesn't work. I pretty sure the problem is that it is a piece of junk.
I can hear the caller but they cannot hear me
The problem is that the mouth piece of your phone is bad that is why the cannot hear your voice.
I advice you get the mouth piece of your phone replace because it is bad and that is why your callers cannot hear you.
All you need to do is to change the mouth piece of your phone and you will see that your callers will hear after you have replace the mouth piece of your phone.
Meanwhile, you can get hands free pending the time you will replace the mouth piece of your phone.
Take care.
Aug 05, 2010 • Cell Phones
My callers are unable to hear my voice
Take care.
2answers
BLOCKED CALLS
If you subscribe to a caller ID service through your phone provider, you can block
specific fax numbers so the device does not print faxes received from those numbers.
When an incoming fax call is received, the device compares the number to the list of
junk fax numbers to determine if the call should be blocked. If the number matches a
number in the blocked fax numbers list, the fax is not printed.
Set the junk fax mode
By default, Block Junk Fax mode is turned On. If you do not subscribe to a caller ID
service through your phone provider, or do not want to use this feature, you can turn
off this setting.
To set the junk fax mode
▲ Some models have a Block Junk Fax button. Depending on the model you have,
do one of the following:
Block Junk Fax button: Press the Junk Fax Blocker button, select the Block
Junk Fax option, and then select On or Off.
Color display menu: Press Setup, select Basic Fax Menu, select Junk Fax
Blocker Setup, select Block Junk Fax, and then select On or Off.
Add numbers to the junk fax list
There are two ways to add a number to your junk list. You can select numbers from
your caller ID history, or you can enter new numbers. The numbers in your junk list are
blocked if Block Junk Fax mode is set to On.
Caller id dont work
just connect one end of the phone plug to the id caller,then connect the outlet of the caller id and fix it to phone...........even then if u hav problem, may be ur caller id doesn.t hav batteries..............otherwise u may hav some problem in the id caller socket where phone plugs r inserted................
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
