You can go to the setting and uninstall the antivirus if you are facing problems like this than you can use this toll free number 1 -855 770 7730
I also had this virus on my PC. Just follow these removal instructions:
How to remove Antivirus 7
Antivirus 7 removal instructions
If you would like to remove AntiVirus 7, click Start -> Control Panel -> Add and Remove Programs. Scroll to the program you would like to remove and click remove.
If you still have issues please let me know if it is Norton AntiVirus 7 or another program. And I can help you further.
Thanks
there are many ways to improve startup time. some safe steps to follow are the following.
1. run "msconfig" - startup tab - disable all except your antivirus software (i use a light microsoft security essentials). services tab - click hide microsoft services, and disable all other services which show up except for services which run with your antivirus program. boot tab - advanced options: select hiytghest number of processors and highest available selection for memory. also check "no gui boot".
2. run disk cleanup or clean manager from windows system32 folder. clean all system files and drive files.
3. run checkdisk and defrag your hardisk.
4. update antivirus and scan your pc. i suggest microsoft security essentials for antivirus, malwarebytes antimalware and trojan remover for malware and other spyware.
Download and install Malwarebytes here -http://www.malwarebytes.org/mbam.php Or alturnitve you can delete it manually How to remove Antivirus 7 manually: Manual removal of Antivirus 7 is a feasible objective if you have sufficient expertise in dealing with program files, processes, .dll files and registry entries. The files to be deleted are listed below: %Documents and Settings%\All Users\Start Menu\AV %Documents and Settings%\All Users\Start Menu\AV\Antivirus7.lnk %Documents and Settings%\All Users\Start Menu\AV\Uninstall.lnk %Documents and Settings%\[UserName]\Desktop\Antivirus7.lnk %Program Files%\AV %Program Files%\AV\Antivirus7.exe %Program Files%\Common Files\Uninstall %Program Files%\Common Files\Uninstall\AV %Program Files%\Common Files\Uninstall\AV\Uninstall.lnk %Program Files%\Antivirus7AV %Program Files%\Antivirus7AV\Antivirus7.exe %Program Files%\Antivirus7AV\unins000.dat %Program Files%\Antivirus7AV\unins000.exe %WINDOWS%\system32\UpdateCheck.dll The registry entries that need to be removed are as follows: HKEY_CURRENT_USER\Software\EVAACD HKEY_CLASSES_ROOT\CLSID\{35A5B43B-CB8A-49CA-A9F4-D3B308D2E3CC} HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{35A5B43B-CB8A-49CA-A9F4-D3B308D2E3CC} HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run ?Antivirus7′ HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\5.0\User Agent\post platform ?WinNT-EVI 25.11.2009′ HKEY_CURRENT_USER\Software\FNULL246 HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{6A23338A-C725-48D0-BA96-B12FDD22DD39}_is1 Please, be aware that manual removal of Antivirus 7 is a cumbersome process and does not always ensure complete deletion of the malware, due to the fact that some files might be hidden or may get reanimated automatically afterwards. Moreover, manual interference of this kind may cause damage to the system. That?s why we strongly recommend automatic removal Antivirus 7, which will save your time and enable avoiding any system malfunctions and guarantee the needed result.
