Whirpool Super Capacity 465 Self-Cleaning Gas Range error code F5
Having problem with door lock - it performes buz-z-zering noise and shows error F5. After ressetting it looks OK, and then by itself it starts making the same sound again.
I have the same problem, for the past 6 months my oven go's to F5 and locks when during pre heat and also when cooking something, I'm still waiting to hear something from whirlpool co. I have made several attemps to contact but never heard back. and I'm still cooking in my inlaws apartment in my basement . I'ts inconvenent and not to fun on the holidays. PLEASE FIX IT SOON>>>>> THE UNHAPPY COOKI have the same problem, for the past 6 months my oven go's to F5 and locks when during pre heat and also when cooking something, I'm still waiting to hear something from whirlpool co. I have made several attemps to contact but never heard back. and I'm still cooking in my inlaws apartment in my basement . I'ts inconvenent and not to fun on the holidays. PLEASE FIX IT SOON>>>>> THE UNHAPPY COOK
AnonymousMar 26, 2014
Will not clean. Error lights come onWill not clean. Error lights come on
You can't post conmments that contain an email address.
Re: Whirpool Super Capacity 465 Self-Cleaning Gas Range...
Facing the front of the oven (while off) put your hand along the back of the oven toward the top left side. there should be a techinical spec sheet with a list of what the codes mean and possable solutions.
WHIRLPOOL Range/Stove Oven Fault Codes, Common
Failure CodeConditionCheck/Repair
Digit Failure Code2
F1
Analog to Digital Failure
Disconnect for 30 seconds - if display reappears - replace control board
F1
Safety flip flop
Replace board
F1
Shorted keypad
Replace keypad
F3
Oven temperature sensor opened
Replace oven temperature sensor
F2
Oven temperature sensor shorted
F3
Oven too hot
F3
Clean temp too hot
F5
Check door/latch switch
Replace switch if defective
Hello Michelle!
Crazy to hear, but this is actually a touchpad failure.
Luckily, we at FixYourboard.com have a solution.
Read more about the cause and fix in our blog! F5 E1 Error Code Whirlpool Built In Double Wall Oven
Feel free to contact us if you have any questions. [email protected]
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
1. Check keypad connector for firm connection (keypad connects to control board). 2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Hi Thanks for using FixYa. This error means that
you’ll need to check the door latch/switch and replace the part that has gone
bad.Please do rate the solution
if the issue is resolved or post a comment for further assistance. Thanks Rylee
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused. You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display. This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
I had the same FSE error which the whirpool web site advises that you will need to schedule a service appt to fix. Instead I leaded against the door while initiating the cleaning cycle and the door locks and oven cleans fine.
