I getting the problem in Xerox 3100mfp "Printer Error Fuser Temp. in xerox 3100mfp" please sugest me
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
Thanks yaar its realy very very helpful thanks again
THANKS REALLY , ITS CORRECT , MY PROBLEM SOLVE ONCE AGAIN THANKS
thanks sir my problem is solve on your direction,,,,(DIGITAL ENTERPRISES),,,jbk,,,
Please service your printer section fuser.
May be sume of waste tonter covered thermostate,so it can not pass normal temp.clean it properly then fix your problem.
Press menu (downarrow) button ,press # , Press T, printer fuser error has reset.
that is only solution and simple no need to open the printer or doing anything else, enjoy
waqas (pakistan)
* I
bought an IC and soldered on the board now and never needed the chip,
printing and copying throughout the useful life of the machine, just put
toner and ready.
* While the "Fuser Error"
I also found the solution:
- Select MENU then * # then press OK CSO1
show will appear CS01 - 00,100,001 10,100,001 to modify and press OK. CS02 appears
press STOP. Made this disconnect and
reconnect xerox 3100 and is ready only joy.
* I
toner and ready.
* Comprei um CI e soldei na placa e agora nunca mais precisei de chip, impressões e cópias por toda a vida util da máquina, só colocar toner e pronto.
* Enquanto o "Erro no Fusor" também achei a solução:
- Selecione MENU depois * depois # mostrará CSO1 pressione OK vai aparecer CS01 - 00100001 modifique para 10100001 e pressione OK. Aparecerá CS02 pressione STOP. Feito isso desligue a xerox 3100 e ligue novamente e pronto é só alegria.
