hi sir iall so same problom my 6600 nokia model . my mob. gallery, bluetooth, celander,camear ont workig. so plz. send my email add. solution. thank.hi sir iall so same problom my 6600 nokia model . my mob. gallery, bluetooth, celander,camear ont workig. so plz. send my email add. solution. thank.
If the gallery is saying opening but it is not oening then fillow the folling steps:-
1>take out your memory card & then switch on. if the gallery is opening after taking out the m.m card then again insert the m.m card & delete unwanted &unnecessary softwares from application manager.
solution for 6600 bluetooth and gallery cannot open
step 1) make a jumper (you can see the encircle terminal of bluetooth ic) then assemble the mobile,turn it onstep 2) OPEN FIRST THE GALLERY WITHOUT MEMORY CARD,THEN OPEN ALL THE IMAGES,MUSIC ETC. INSIDE OF YOUR GALLERYstep 3) TIME TO TURN ON YOUR BLUETOOTHstep 4) PUT BACK THE MEMORY CARD AND DO 2 AND 3step 5) then remove the jumper and do step 2,3,4..if still the cannot open again,put the jumper and reheat the bluetooth ic and repeat it step 1,2,3,4.I ..GOOD LUCK TO ALL WANT TO TRY! JUST TRY IT THERE IS NO RISk
the p[hone need to be reformatted try pressing and holding the green button, *, and the number 3 button while the off the press the on key while holding the 3 keys
you should try to reset/format your phone,
sometimes we install some applications in phone, it makes unnecessary library files,
it causes problem in normal functions of the cellphone, like Camera not work and stuff like that.
yez.,, its a hardware problem, you just have to replace the bluetooth module of your phone, or go to a near repair cellshop and ask them to do that,, when you open gallery it only stuck up on opening and when u use your camera, it says temporary overload ryt?? and some application won't work, the only thing is to replace the bluetooth module of your phone
My nokia 6600 gallery does not load. It shows "opening" and keeps showing the opening message and hangs. The bluetooth. First it said Unable to connect , when i click pair to device it says "system Error". and Now when i click bluetooth it doesnt load options. Other than that the speed of my phone is very slow.
if u have facing this prob. then switch off the phone and then switch on the phone do this procudure 3 times
bluetooth\ says operation failed\Gallery showing opening
same problem
hello sir me gallery kholta ho to app closed likhta hai
