Bloomfield 8571 Coffee Maker Logo
Posted on Mar 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our Bloomfield 8571 stopped brewing hot coffee. The burner works but when you brew coffee it looks like tea and is luke warm. The resivoir seems to be cool. Do you know what it could be so I can get parts for it?
Ernest R
Level 3:
  • Master 1,618 Answers
  • Posted on Mar 13, 2010
Ernest R
Master
Level 3:
Answers
1618
Questions
0
Helped
730016
Points
3103
Check the thermostat on the boiler tank.
What can I do to have the Ready to Brew light come on? I tried to slowly pour in water and fill water tank but doesnt work.
Be sure spray disk and brew gasket are properly installed in the
brew head.
Be sure the water supply is properly connected and the water
supply valve is turned
ON
Be sure the WATER TANK IS FILLED
BEFORE plugging the brewer into a receptacle, or otherwise
connecting brewer to electrical power
THE WATER TANK MUST BE FILLED
Place an empty decanter under the brew head. Lift
the pour-over cover then pour warm tap water into the pour-over
opening until water flows from the brew head. When water stops
dripping from the brew head, empty the container.
Once the tank is full of water,
connect the brewer to electrical
power. The heating elements will begin heating the water in the
tank.
When the water has reached the proper temperature, the
"READY To BREW" light will glow. http://www.cdccoffee.com/pdf/bloomfield-8571-8572-user-manual.pdf
1helpful
How do I set the brew ratio?
Hello, I have worked on many bunn and other make ice tea makers but am not too familiar with this one, but as is common to all there should be 2 timers, one for the hot one for the cold. They are normally located under the top panel or inside the front panel. for 3 gallons you should be brewing 64oz of hot water through the 1oz tea bags (3-4) depending on taste as a rule of thumb. Please feel free to comment again if you have any other questions. Good Luck! Mike
2helpful
Our church received a Bloomfield Koffee King model 8571 and no instructions on how to set up and use the coffee machine.
Hi, Get 2 pots place one under the spray head with the filter cone in....now fill the other coffee pot and start to pour water through the lid top front...keep pouring water through (about two and a half pots) until water starts to pour through the cone....now the tank is full plug her in and turn on the power switch at the back and also the front if there is one....place filter in cone..put coffee in filter...pot on burner...wait about 25 minutes until water in tank is hot...when light on front comes on pour another pot of cold water through the top and you will get a pot of hot coffee in bottom....I also think this machine can be hard wired into water main....get plummer to hook up...follow same procedure but instead of pouring water through top for coffee..hit brew switch. if it poors too much of too little you will find a timer in the machine you can adjust to allow more or less water...hope this helps.
Bloomfield 3-pot coffee maker won't brew
These macines have an internal water heater that should be clened periodicly (monthly per manufacturers instructions but I do it quarterly/semianually/when it gets noisy :) ). The machine will have to be disasembled to do this since the tank will have to be flushed when you do this to get the chemicals out of it (vs running a pot of vinegar through your Mr. Coffee machine at home), Depending on how much scale has built up in the tank this could take several cleaninings. Scale deposits can over time impair/damage the heater or thermostat but replacement parts are cheaper than a new machine and the machine will outlast and outperform a standard coffee maker. BTW, my 8572 3 burner was built in 1972, I bought it at a flee market for $25 10 years ago put $100 in parts to get the push to brew and hot water on tap working again and it made two great pots of coffee this morning.
2answers
Instructions for bloomfield 8752 same as 8571?
I have a 8571. Bought it used. No instruction Manual. Plug it in, turn on the left burner, poor in water water immediately drains through. I that a valve problem?
1helpful
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
2answers
Bloomfield Koffee King coffee maker
TRY REPLACING THE SEALS IT WORKED FOR ME
Top Bloomfield Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Bloomfield Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
