Nothing moves when I try to adjust height according to instructions
There was a reply found previously that worked for me: place the fill valve on a hard surface like a desk or table; with both hands on the top of the fill valve push down. That collapsed the fill valve twist tube and I could then adjust it to the proper height. Thank you to whoever posted that! It worked!
You all most have to adjust the height before its installed,then you just hold the bottom and turn the top.
12. IMPORTANT: Always clear sand and rust from system. Make sure
water supply is shut off. Remove valve TOP by lifting arm and rotating
top and arm 1/8 turn counterclockwise, pressing down slightly on cap.
13. While holding a container over the uncapped VALVE to prevent
splashing, turn water supply on and off a few times. Leave water
supply off.
14. Replace TOP by engaging lugs and rotating 1/8 turn clockwise. MAKE
CERTAIN TOP IS TURNED TO THE LOCKED POSITION. VALVE MAY
NOT TURN ON IF TOP IS NOT FULLY TO THE LOCKED POSITION.
15. Turn on water supply. Adjust water to desired level by squeezing water
level adjustment clip and moving FLOAT CUP up or down along stainless
steel link. Check for leaks, then check for proper flush.
If valve continues to run:
IF FILL VALVE WON'T TURN OFF,
ā¢ There may be debris at seal - repeat Steps 12-15.
ā¢ The seal inside the valve top may be damaged -replace with genuine
Fluidmaster 242 seal.
Is this for a pull-up drain stopper on a faucet?
