Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
Posted on Mar 11, 2010
Can i use an N wireless adapter with this router?
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Mar 11, 2010
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
5075
Points
70
Sorry, but this router only accepts 802.11b & 802.11g connections only.
Have install netgear range booster to wireless router but says limited connectivity
This can occur when the wireless adapter has trouble connecting to the wireless router.
It may not get an IP address from the router or the wireless adapter encryption setting didn't get an the encryption authentication from the router.
In this case right click on the wireless adapter on the Task bar and click Repair. This will make the router re-issue an IP address and authenticate the adapter's encryption setting.
Can i use any brand of wireless n adapter for my router
Yes. You can use this to anykind of router, be it Wireless G or N type of router. But this is adapter suites best for wireless N type of router.
1helpful
My D-Link-122 wireless adapter broke. Is there
Generally all the Wireless Adapter that are B/G/N Wireless Standard compatible and avaliable in the market will work with your Wireless Router, depends if you want to go with a PCI adapter or a USB adapter.
1helpful
Can i use Bluetooth USB Adapter to connect PC to wireless router?
No, I am afraid not. the bluetooth adapter will not connect to your wireless router because as of now there is no router that support that function.
you can buy a USB wireless adapter instead.
thank you for using Fixya
1helpful
How does the pc wireless adapter work for laptops with embarq equipment. currently using dsl with embarq.
pc wireless adapter will work then if you have also another network like wireless router or another PC or Laptop with wireless adapter, if your going to use this wireless adapter network in pc to pc is you are going to setup by adhoc to adhoc connection, itself detect for sharing a network without any router needed, but if you do such simple network connection use wireless router, its definitely work easily. Aumatomaticall detect wireless router on your wireless adapter network.. Good luck!
2answers
Wireless n gaming adapter not working with wireless b router
I suggest you to type all wireless settings that you have on the router manually in the wireless settings of your xbox 360.also depands on the security compatibility between your router and your adapter,i mean to say try wep and wpa.and your wireless adapter is reading your wireless router as G because it`s of G standard(adapter).try putting all wireless settings manually and it should work.
hope that will help you.
How to connect wireless router, Netgear WGR614, to my computer?
4 steps to set up your home wireless network
1.
Choose your wireless equipment
The first step is to make sure that you have the equipment you need. As you're looking for products in stores or on the Internet, you might notice that you can choose equipment that supports three different wireless networking technologies: 802.11a, 802.11b, and 802.11g. We recommend 802.11g, because it offers excellent performance and is compatible with almost everything.
Shopping list
• Broadband Internet connection
• Wireless router
• A computer with built-in wireless networking support or a wireless network adapter
A wireless router
The router converts the signals coming across your Internet connection into a wireless broadcast, sort of like a cordless phone base station. Be sure to get a wireless router, and not a wireless access point.
A wireless network adapter
Network adapters wirelessly connect your computer to your wireless router. If you have a newer computer you may already have wireless capabilities built in. If this is the case, then you will not need a wireless network adapter. If you need to purchase an adapter for a desktop computer, buy a USB wireless network adapter. If you have a laptop, buy a PC card-based network adapter. Make sure that you have one adapter for every computer on your network.
Note: To make setup easy, choose a network adapter made by the same vendor that made your wireless router. For example, if you find a good price on a Linksys router, choose a Linksys network adapter to go with it. To make shopping even easier, buy a bundle, such as those available from D-Link, Netgear, Linksys, Microsoft, and Buffalo. If you have a desktop computer, make sure that you have an available USB port to plug the wireless network adapter into. If you don't have any open USB ports, buy a hub to add additional ports.
2.
Connect your wireless router
Since you'll be temporarily disconnected from the Internet, print these instructions before you go any further.
First, locate your cable modem or DSL modem and unplug it to turn it off.
Next, connect your wireless router to your modem. Your modem should stay connected directly to the Internet. Later, after you've hooked everything up, your computer will wirelessly connect to your router, and the router will send communications through your modem to the Internet.
wireless_chart.jpg Next, connect your router to your modem:
All i need is a wireless router and an adapter right?
If your router is protected by password you need to configure it but the only equipment you need is the router, the adapter and a provider.
Drivers 4 Linksys BEFW11S4 ver. 4
Your wired network adapter will talk to a wired router without a driver for the router on your computer. Your wireless adapter likewise will talk to your wireless router without a driver for the wireless router on your computer. Your wired and wireless adapters however do require drivers and the wireless adapter can require configuration. Please provide the manufacturer and model of your computer so I can learn about your wireless adapter and we can work to get it connected to the router.
Do you currently have your router connected to your internet service providers connection and do you have another wired or wireless computer successfully using this device to access the internet?
Dell wireless 1450 usb adapter
any wireless router will be ok, they are all the same standard normally 802.11G, but if your adapter is 54MBPS go for a 54G router, or if 108MBPS, go for the faster router.
Top Actiontec Computers & Internet Experts
Jesse Walters
Jesse Walters
NOEL
NOEL
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
