Tascam 2488 Portastudio Multitrack Recorder System Logo
Posted on Mar 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tascam 2488 digital portastudio
i have just been using my tascam 2488 portastudio and whilst shutting down the mains cable got accidentaly disconnected, now when i try to turn it back on i keep getting this erroe message: cannot boot not detect hdd correctly please power off and check h/w. can you possibly give me any information on how to solve this, im worried i have lost the data on the hard disk,
many thanks les.
Ginko
Level 3:
  • Tascam Master 19,396 Answers
  • Posted on Mar 08, 2008
Ginko
Tascam Master
Level 3:
Answers
19396
Questions
25
Helped
8074974
Points
55462
Your HD risk to be corrupted, probably need to be removed and tested on a different device, I see if I can find the schematics
regards
  • 1 more comment
  • Ginko
    Ginko Mar 08, 2008
    First do an hard reset, just in case.It means just disconnecting power cable from outlet 10 minutes or so, connecting back, restarting device. Try it.
  • Ginko
    Ginko Mar 08, 2008
    also turn it on and leave it on for 30mins 1 hr with the error message on display.The tascam will try to do a disk check after a while, you will see no change. If you are lucky the machine will restart normally after one hour and all your songs and files will still be in their place.
  • Ginko
    Ginko Mar 08, 2008
    I gathered some information on your case. seems you are not the only one having this problem, here is a forum about same troubles with hdd in 2488.
    If the above did not work, then the situation is :
    hd inside is faulty, fixing it will be quite easy, the main problem will be to recover all your songs and files from defective hard drive first.
    First of all, if the machine is under guarantee send it to a service centre and ask them to recover your files from old hd after changing it. If it is possible to get files, they will get them.
    Here is service search and contact for tascam
    If you have to do the job yourself then you have to remove hdd, I think you will have to unscrew a door at the back of 2488. Unfortunately documentation from tascam is scarce, and I couldn't find schematics or servige guide.
    Once you get the hd from inside I suggest monting it on an external hd usb caddy enclosure. so that you can connect it to a pc and get files out.You can buy caddy for low price in any computer shop.
    Buy a new hd up to 120GB( do not know which is max hd size for 2488). Screw it back where you removed the original hdd.If you do it properly the format procedure should start in automatic once you restart the 2488.
    Here is the guide with addition from tascam It also explains how to format newly fitted hdd in case you have troubles.
    regards
1helpful
MY PC wont recognize my Tascam Portastudio device2488, i have Vista
Tascam 2488:
I use Vista and my 2488 MK1.
When you plug in the USB cable from the 2488 into your Vista PC, Vista will always say 'not recognised'.
You do not need any PC drivers for the 2488. On the Tascam 2488, go to 'Menu', then 'Disk', then 'USB Open/Close', then click 'Yes'.
On your PC the 2488 will appear as a new hard drive in the 'Computer' folder, called HDR2488.
You'll see three folders in there: WAVE, SMF and BACKUP.
Use the WAVE folder to import and export WAV files, the SMF folder to import midi files to the 2488, and the BACKUP folder is where you can import and export Backup files to and from the 2488.
Hope this helps!
2answers
I want to erase all of my data on the tascam 2488
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Chapter 7, page 45 talks about erasing partitions permanently.
How to download from the Tascam 788 to the CD Burner?
Chapter 8
Hi im new to using the effect send on my tascam 2488 neo. How do i set the connections? how dose it work?
I think if you had the manual you would know the answers.
2answers
Instructions
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
Link to the Tascam 2488 application guide:
http://tascam.com/Products/2488/2488_AppGuide.pdf
Here's the link to the Tascam 2488 quick start guide:
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
Hello
http://tascam.com/details;8,16,5,19.html
That is the link to download the manual in pdf format.
Tascam 2488
Top Tascam Audio Players & Recorders Experts
John
John
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
