GE JVM1650 1000 Watts Microwave Oven Logo
Posted on Mar 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our microwave oven will not cook or reheat at all. The lights, clock, etc. all work. Is this also the magnetron leaking? Is this expensive to repair and can you do it yourself?
Anonymous
Level 3:
  • Master 1,476 Answers
  • Posted on Mar 12, 2010
Anonymous
Master
Level 3:
Answers
1476
Questions
0
Helped
340405
Points
4062
I have a tip which explains all your questions at http://www.fixya.com/support/r4223574-microwave_oven_will_not_heat Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
On model mh1160xss-0 whirlpooll microwave the fuse blows everytime you turn on cook
The magnetron is shorted or the inverter board is defective if microwave is 7 years old or less.
1helpful
Have a 22" microwave oven
There are a few things that will cause this problem, the high voltage diode, or the high voltage capacitor, and the magnetron are usually the culprits. I find that one or more of these parts will go making the cost to repair at least $100.00 and up.
The controls along with the clock and timer works on the mircowave. The problem is that the food does not cook or heat up.
probably a defective magnetron; very common for this vintage microwave. there are usually generic magnetrons available; as the original GE part will be expensive.
Not heating up anything
Tat would be a magnetron problem. The magnetron is what provides the heat
9helpful
2answers
Model JVM1650WH02 will shut off about 2 seconds or less into cook time. everything else works such as light and clock and sometimes the wave will cook.
magnetron is leaking internally, do not use until magnetron is replaced. the mag creates interference with the control board and resets it
Clock works fan turn on but no airflow and time cook, reheat and surface lights do not work
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
2answers
Kbms1454r
Your magnetron is leaking and needs to be replaced.
Clock Trips
Are you saying that the oven seems to shut off while cooking? Does it also happen if you cook at full power? This may be a bad connection on the controller (which we repair) or a failing magnetron. Please give usd a little more detail so we can follow up.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
