My smoothfitness 5.25 treadmill is stuck at the highest incline. When I press the incline down arrow, the numbers change but the deck doesn't budge
Unplug your unit take the motor shroud off and you will see a circuit board (Motor Control Board) their should be L E D s on the board. Now plug your unit in and you will see these light up if you have a second pair of hands that can help you have them press you incline controls.
You should see one of these L E D s light up followed with a click of a relay this activate the incline motor some of these boards will have a 3 amp fuse to protect the board from damage , if you see a open fuse replace it with the same exact fuse. If it blows again either you have a shorted armature winding or the worm screw is frozen. I would call Smooth Fitness, depending wiether this was made by either Sports Art Fitness or Keys Finess they will direct you to theproper parties.
