The stick shift knob appears to be not working anymore. I am able to drive and reverse the car but cannot take the keys out of the car. Is it still OK to drive the car?
You mention the knob on the shifter is loose. Do you remember if the knob has always been loose or is this recent? I ask because I thought there was a button to push or a lever to lift to move the shifter into or out of R and P. So that you might not accidentally push the shifter into either of those settings and possibly damage the mechanism. If there is a lever or button, it might be that the button or lever doesn't fully disengage when you press it BECAUSE the knob on the shifter is loose. You might need to tighten the knob. Might need hex keys / Allen keys or small screwdrivers to tighten the knob. good luck.
is this a automatic transmission or a stick if its a stick could be clutch plate when you put it in reverse and it does nothing its an internal problem sorry have a free check done of it at a transmission shop
Check the transmission oil level first but after that the problem is most likely in the transmission unfortunately. also check shift cable to transmission.
Either the shift knob or the actuator rod under the shift knob has worn out.
Remove the shift knob and pull the actuator rod (plastic) out of the shift lever and inspect it for wear or damage. If the rod is not worn or damaged, replace the shift knob and you will be good to go.
Good luck.
HI, there is a solenoid(switch) that's located in shift linkage housing that works in conjunctions with the brake pedal when you shift from park to reverse or drive. this is a safety situation.
Sometimes, this solenoid(switch) can malfunction or die. In this case, it will prevent the gear shift lever from moving into the reverse or parked position. Simply replacing this shift lever solenoid will fix this issue. You can expose the solenoid by disassembling the shift stick housing,
There is a plasticactuator stick under the shift knob. Remove the "horse shoe" clip from the shift knob and remove knob by pulling strait up. You can twist it right and left a very small amount to loosen the knob, but not much.
Once you have the shift knob removed you will see the plastic actuator stick. Push down on the stick and put shift lever in park. If that works, the shift knob or stick is worn out.
Let me know.
Regard,
Most likely the turning on and off might have trigered or burned out your relay switch located in the front of your engine. The overdrive button on your nissan was only ment to be used sporadically and not as a stick vehicle ( According to your expression ). You can purchase this relay in your nearest nissan dealer. Good luck.
that means the pin that the knob presses down is stuck on something. if you take the shifting panel off it showes everything. then there will be a plastic guide. see what the pin is sticking on and there you are.
