I have a mp3 ilo that has stopped accessing my sd card music. it was working then stopped . the player screen flashes while trying to access. version 3.120.go2 the flash music is fine.
Hi sfarmer1983...
Plug your SD card into an SD card reader...the plug the card reader into the computer.
The computer will recognize the card reader and open a window...you will select "see files"...
Highlight the songs and put them in Windows media Player...plug your mp3 player in while the computer is running and Media player is running...Media player will recognize your mp3 player
Highlight your songs in the SD card reader...drag and drop the files to Media player...
Please take time to rate me
You need to format all new cards. Does your Mp3 player show up as a drive when you hook it up to your computer if so open that drive right click on format use FAT32 for windows os. If your Mp3 player does not show up as a drive use the SD slot on your computer to format. Choose the SD card slot drive right click on the drive choose farmat... use FAT32 for windows os. and you should be off and downloading great tunes... Good luck hope that helped.
Not sure if you have found the solution to your
mp3/SD-card problem, it has been almost a month. Obviously I had the same
problem. That's how I found your question. What I did was re-format both the mp3
and SD, then loaded the SD card first and sofar so good.
You cannot just move WMA songs onto the card and play in the MP3 player. MP3 format may work this way, but for sure the player only seems to be able to recongize WMA files when syncd through Windows Media with the USB cord attached. Be sure the DESELECT 'copy folder hierecy' under the sync options/properties of the MP3 player drive or SD card drive.
When using XP Pro and Windows Media Player you can transfer WMA but you have to go into the PROPERTIES of the drive (mine was mp-556/G: drive) and DESELECT the option to transfer folder hierecy. The MP3 player is not able to reconginize the folder structure it usually creates.
This player only seems to be able to transfer MP3 format with Vista, using windows media player sync. I can syne MP3s formats, but not WMAs at all. Unless someone found otherwise
What, you actually hotwired a flash card into the Ilo? Impressive. Or are you trying to get the Ilo to play music from an SD card, when you have both plugged into the computer?
If you're talking about the first, then I'd say you did a good job at NOT destroying your Ilo. If its the second, then unplug your Ilo, put your headphones into the headphones jack in the computer, and play the music from your computer.
