You simply get a 22o Volt to 120 Volt stepdown isolation transformer, these can be readily obtained from any good transformer manufacturer or say eBay, Craig's list etc.
like in the link below
http://cgi.ebay.com/1000-Watt-Voltage-Converter-Transformer-110-120-220-240_W0QQitemZ360235854330QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item53dfbae9fa
Find the breaker for it (a double for 220) and substitue a single breaker (for 110). This will leave one wire unused from the breaker box to the outlet. You'll have to change the outlet of course to accommodate a normal 110 plug. You can also skip the breaker part and just change the outlet and cap off 1 of the hot wires. Just make sure to kill the power and be safe!
All the possible problems will mean removing that thing...it is likely that a fuse inside blew, but that may be a sign of bigger problems...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
