Sylvania 6432GG 32" TV Logo
Posted on Jan 15, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sylvania 6432gg 32 inch tv
Will not come back. green lights flash as to trying to come on but just shuts off. any help appreciated, as to problem and how to repair.
thanx,
Doug Wright
[email protected]
Carlos Oliveira
Level 2:
Habit-Forming:
New Friend:
  • Expert 62 Answers
  • Posted on Jan 16, 2018
Carlos Oliveira
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
62
Questions
0
Helped
25115
Points
110
I recommend you do not fix It. LCD TVs are inexpensive today and have much better performance.
3 Related Answers
Anonymous
  • 20 Answers
  • Posted on Nov 06, 2007
SOURCE: sylvania srt2232x vertical size
Before you replace any parts, have someone (TV service tech) check the vertical size settings in the service menu.
Happy viewing!
Toprol
Anonymous
  • Posted on Dec 23, 2007
SOURCE: sylvania 6432gg
I've got the same problem too. TV is approximately 10 months old... I think it's a piece of junk.
Anonymous
  • 8 Answers
  • Posted on Sep 22, 2009
SOURCE: Problem: my sylvania SRT2232X 32 inch has green tint on every cha
A green tint can be caused by over drive of the green circuit or lack of enough red or blue.Either way it leads back to the tube having a problem. If it is even available the cost of replacement would well exceed cost of buying a new TV.
1helpful
How to replace antena o a silvania TV 6432gg
Depending on your comfort level and soldering skills this is fairly straightforward pull the back off the TV identity the part, buy a replacement at radio shack swap it out
How do I hook my sylvania model number 6432GG TV to my ASUS laptop model #D550MAVD801?
The only inputs tho the TV are cable in and AUDIO / VIDEO in.
You can use 'stereo patch cords', to plug into the tv. Check with your local computer store to see if you can find adapters to plug into the computer and change to RCA jacks.
All of that means, you probably can't.
Need Sylvania 6432GG 32
0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
I receieved a SYLVANIA 6432GG TV with a remote. The remote control doesn't work. The previous owner had programmed a Comcast remote control to use on the TV. I don't know how to reprogram t
GOOGLE THE MODEL NUMBER OF THE SET (IF ORIGINAL REMOTE) WITH "manual" which would get the owner manual to do this.
Each set is different in this process.
Do u have the service manual for SYLVANIA 6432GG
Hi mreyes518,
I have a pdf file format of SYLVANIA 6432GG Service Manual but I don't know how can I send it to you if ever possible because we are not allowed to ask your email add.
This is also available at this LINK.
Jdvillanueva
Sound but no picture
probably this tv has a transistor damaged, but you can try to re solder all the leads and try to switch it ON again. beaware not to short the component leads.
Changing from cable to antenna
Angel,
You need to get rabbit ears. Hope that helps.
Sylvania 6432gg
NO POWER
try to check the fuse first.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
