Changed battery and the same result turns out
Actually when you want to switch on your phone, but it's not turned on,but when you charge the phone, the battery indicator goes up, it just mean one thing : YOUR ON-OFF SWITCH is broken!!
so how to replace this on off button? well, if you can, open the casing of your phone. you'll see the real on-off switch below the usual on-off button we have on the casing. press it. Good luck ^^
Btw if you have no luck pressing the real on-off switch, replace it, bring it to technician. It shouldn't cost you more than 10usd if you told them to problem (if you didn't tell them, they'll say, oh your IC got broken, oh your phone will cost much on the fixing, oh this oh that, they'll **** your money..). Just said, hey, my on-off switch got broken, please fix it.
You can get my head cut-off if I' wrong.. haha, I'm pretty sure that's the problem.. well there's a little case of broken circuit that might cost you much more, but shouldn't be more than 20usd too ^^ Good luck
My n70 dose not open it just light when put into the charge without showing the nokia just white light please help me cus i cant buy anther phone thanks.
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know, you need someone to press the ON button.
Hi, i have got Nokia N70 music edition and it is not switching ON, when i press the power button I just get the bright white screen then nothing else it remains the same. please help resolving this problem.
N70 cell not turn on
I also have a nokia n70 and when it just goes white and says nokia, it stays like that for a while but when i press the on button and i keep pressing it then it changes to the front menu of your phone
SOURCE: Nokia N70 Power Problems
my fone is charged...all of a sudden i switch off and then when i switch it on..all it shows is nokia nothing else...i have a N70 ..please help me
SOURCE: nokia n70 lcd problem
ur phone firmware is corrupted try to give it a flash
to perform that u need a very expensive tools so the better way is to give it to a trused phone repairshop and tell him i want to flash my phone
plz rate this post as good as u can also if this is not helping check the lcd connector first and clean it using medical alcohol and brush carrefully
my n70 does not turn on at all .
how do i fix it myself ?
an almost new nokia n70 will not turn on. tried to remove sim card and fully charged battery but still did'nt turn on.
My son is experiencing the same problem with his Nokia N70 Music edition (black one). We have tried charging the battery completlely. We purchased a new battery as well, charging that one completely also. The same thing happens on both, it will only light up when plugged into charger, shows Nokia open screen and that its charging and then thats all, nothing happens after that and if unplugged does nothing at all.
My nokia N70 will only light up when plugged into charger, shows Nokia open screen and that its charging and then thats all, nothing happens after that and if unplugged does nothing at all.It does not format as well by pressing 3,*,call key
Ok so my enV wont turn on and it's fully charged sometimes it would work if i put in the charger and then real quick took it out then pressed the PWR button it would turn on now it just wont turn onĀ
*i don't think the on and off switch is brokenĀ
