HP OfficeJet D135 All-In-One InkJet Printer Logo
Posted on Mar 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP Officejet D Series Multifunction d135 Error Message Interpretation
I frequently, but not always, get an Error message upon Fax transmission (sending a fax). It's Error 351.
Where can I find an interpretation of these error messages?
The Reference guide provides none. A quick google search and a visit to the HP website provided no error definitions---at least none that were easy to find. -Sproutman
Anonymous
Level 2:
Novelist:
  • Expert 188 Answers
  • Posted on Mar 20, 2008
Anonymous
Expert
Level 2:
Novelist:
Answers
188
Questions
Helped
74323
Points
264
Hi Sproutman.
Please click on the web link given below and perform the steps provided in the web page to get the issue fixed.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&lc=en&dlc=en&product=64986
Click on the web link given above.
Scroll down to the error code and read the error code.
1helpful
I bought all new cartridges, inserted them the way they were removed, but message board still says defected cartridges. how to install ink properly and make error message disappear?
Here is a video from HP explaining the process. IF you followed this procedure and are getting errors, then you may have bigger issues. I am assuming you are using genuine HP ink, not remanufactured or refilled cartridges.
Replacing Cartridges for HP Officejet Pro 8600 All in One Printer Series...
1helpful
What is the problem and solution to error code 420 or 321
Are you able to send fax to another # ?. Error 420 & Error 321 is mainly due to transmission of signals or incompatibility issue.
Try reducing Fax speed and turn off ECM from Fax menu and check.
Regards,
Sean
Hp d135 all in one printer error message says "turn off and on" and all lights blinking fast
it's almost the (data cable) connected the carriage- it maybe damaged or not connected well.
HP D135 PRINT error
I am sorry the print head goes out on the B And W on these things quite frequently. however you can go to www.hp.com amd go threw thier secdualed way of testing the print head but am sure you will find it defective. I had one and it was a problem. B e aware they have a new head that replaces the old head that lasts much longer.
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
Hp d135 copy function makes copy in green instead of black
ur tri color cartridge may have run out. change it and try again. if it doesn't work try calibrating ur scanner.
9helpful
2answers
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Print heads
You may have looked at this site. You haven't mentioned if you went to HP. Take a look at the link listed. This does include your OfficeJet D135. Post back if this all failed.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&cc=us&lc=en&dlc=en&product=64986&dlc=en&lang=en
map9966
k24674
Grand Canyon Tech
Grand Canyon Tech
