A 900 Firmware error means that something has corrupted the code on your printer.
The easiest way to fix this is to go to www.lexmark.com > Support > Downloads and download the latest firmware for your printer.
Don
Effective Solution to Fix Lexmark printer error code 900:
The appearance of error codes and messages indicate that your printer is unable to perform desirably due to some reasons. Users need to take expert opinion as error code 900 causes problem in their network which ultimately leads to work delay. The consequences are really severe if there is an issue with the user's network or software. Keeping all the things in mind, our executives are providing you with easy troubleshooting techniques to eliminate Lexmark printer error code 900:
§Power off the printer/MFP for at least 30 seconds to clear its memory
§While your device is off, clear any kind of printing jobs from your computer
§Power on your printer once again
§Check if the error code still appears
For More Info Do Visit us: Lexmark printer error code 900:
The 900 error usually indicates a software or communications problem. The first thing to check is the base printer.
Turn off the printer and disconnect every cable, except for the power cord.
Turn on the printer and see if the error returns.
If the error does not return, try to print a test page from the Test Menu.
If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
If the 900 error appears only when you send a print job to the printer, the likely source of the problem is the computer. Turn off the printer. Leave it powered off for 30 seconds or more to clear its memory. Do not power the printer off and on too quickly. Doing so can cause a power issue and create this type of issue.
While the printer is off, clear any pending print jobs from the computer or the network queue. This will prevent any corrupted print jobs from being re-sent to the printer when it is powered back on.
If the error appears every time you power on the printer, regardless of whether you send a print job or not, the likely source of the problem is a part on the printer. There is probably an issue with either the printer or an option installed on the printer. Power off the printer again and remove any installed options from the printer. This would include an optional paper tray, any extra memory, and any optional network cards.
For further assistance, please contact Lexmark Technical Support.
Please click on the link below to see instructions on how to go about the procedure.
For further assistance, please call Lexmark Technical Support.
Ok please try scanning this way
