I have a 17kw inverter there are a problem in this inverter it show operatering frequency but there is no output.
javed akhtar
I have a f5 C1B-3BOA showing a error code E.Punch can you help
paul
There is no E.Punch error and I am assuming you are seeing the E.puch error. This error is triggered when the control card reads a value from the power stage that is different from the last time it was powered up. This can be caused by a defective control card, defective power stage or someone has changed the control card. This is a normal error when the control card is changed. You can try to reset this error by writing a value to parameter Sy.3. Sy.3 is the value read from the power stage so if you hit enter it should clear the error. If it does not then there are more problems and the unit should be repaired or replaced.
Please , i have the same error ; should i use the Operator unit or a Computer to change the value Sy.3 ? TKs
This can be done via the keypad of the display or with a computer and the COMBIVIS software. Having the COMBIVIS software will make things easier as well as allowing you to make parameter list, use the scope and give you more access to the functionality of the inverter.
When machine is running mode they shows inverter side comes E oc
E.OC means that there is an "Over current" situation on the output side of the inverter. Potential short in the motor, motor leads or output of the inverter. Remove motor leads from inverter and try to run the system. If error does not show up, the problem is most likely external to the inverter.
This is the same problem i am facing, but winding is all right, no shorts anywhere. :( i am confused, worked on Accelaration Times but doesnt work...
Forward CONtinues
System is at the commanded speed in the forward direction.
Verify which parameter you are looking at when you say it shows operating frequency. There is a set frequency display and an actual frequency display. What is the actual part number of the unit?
Hi mntech1, i am watching you and wanna appreciate u for ur expertise in KEB combiverts :) Meanwhile friend, i have raised a Question please help me too !!! Thanks in Advance
keb
