Oven wont heat to temp its, displaying no codes, broiler works
Generally speaking, if an electric oven isn't reaching the correct temperature it's usually the element or the thermostat to blame. This tips should help you diagnose what's causing the problem:
If the bake element isn't heating at all or if when it's turned on it starts tripping breakers and blowing fuses than it's probably the element that needs to be replaced. Here's our guide to how to replace a fan oven element:
If the element is heating but the oven temperature isn't accurate for where it should be than it could be the thermostat. You can test these hypothesis out with certainity by testing the continuity of both the element & the thermostat.
You should also visually ***** to make sure that there isn't any loose wiring in your cooker.
Obviously before playing around with the cooker make sure that it's unplugged and drained of residual electricy.
