Garden Logo
Willie Brinkley Posted on Mar 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pull cord stuck on my pressure washer. - Briggs & Stratton Garden
  • ashish beharry
    ashish beharry Aug 25, 2018
    Thanks Jeff vino it worked
Jeff Hino
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 13, 2016
Jeff Hino
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
26040
Points
5
Press on the trigger on the wand to release pressure . then pull on the cord and it should work.
Colin
Level 3:
Genius:
  • Master 1,584 Answers
  • Posted on Mar 10, 2010
Colin
Master
Level 3:
Genius:
Answers
1584
Questions
0
Helped
469399
Points
4520
Need to remove assembly to find problem.
Anonymous
Level 1:
New Friend:
  • Posted on Jun 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
26040
Points
I bought a briggs and stratton power washer and the pull cord is stuck how can I fix this?
3 Related Answers
Phil Rivera
  • 83 Answers
  • Posted on Mar 30, 2009
SOURCE: the cord we pull to start the washer machine is stuck
So it's stuck out? If so loosen the recoil assy's bolts and it will snap back once it's loose enough. This usually happen due to bent recoil cover, swelling of the pull rope, or too much pull rope in the recoil (length).
Or it stuck in and won't pull over. If so remove the spark plug and see if it will pull. Keep away from the spark plug oil since if the unit is flooded with fuel or oil it will shoot out of the hole and cover you with it. If it does not pull over without the spark plug in, there is a 90% chance your motor is blown.
Let me know what you find
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on May 28, 2010
SOURCE: troy bilt 2600psi 2.3gpm model 160 pressure washer
This sounds like the pump has dead headed. I.e. the unloader valve is sticking. Unhooking all of the hoses should eventually allow everything to free up. Once it is free what you should do is add about 3 ounces of oil into the water inlet connection and let the unit sit overnight. Pull the recoil with the switch off to make sure that the oil has passed into and through the pump.
If the engine has frozen in place due to a lubrication problem you can try putting about .5 ounce of oil into the spark plug hole once the plug is removed. Let the oil sit for about 10 - 15 minutes in the cylinder head then pull the recoil with the switch off to clear the oil you added into the spark plug hole before re-installing the plug.
If it locksup yet again after this you wil have to remove the unloader bypass plunger from the pump assy and clean it. You will need to clean all of the seal mating surfaces with a rolled piece of sand paper. Also before re-assembly you must lubricate the seal surfaces with No. 105 Lubrilate "white grease" that is available at any auto parts supply source.
If after all of this it is still locked up the connecting rod has seized on the crankshaft and will require a rod bearing replacement and crank shaft polishing with emery cloth before insxtalling the new rod end bearing.
Thanks for using FixYa.
Kelly
Testimonial: "It freed it up tks"
Anonymous
  • 241 Answers
  • Posted on Mar 24, 2010
SOURCE: pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Honda GCV160 engine Pressure Washer. The pull cord locked up.
Question edited for clarity.
You need to remove the pull cod mechanism as if you were replacing it. You will normally find the cord has moved out of its track. it is also possible that the spring broke and locked up.
My recoil starter won't pull out it is stuck
Just take the cover bolts for the pull cord off. Then see if it works. There are usually two cogs that engage into the shaft of the engine. These cogs push outward when you pull the cord, engaging the shaft of the engine.
Oct 01, 2014 • Garden
Pulley is stuck how do you resolve problem?
Pulley ? What pulley?
If you mean the recoil starter pull cord is stuck it might be a simple fix. Did your machine tip over on its side?
If it did oil often flows into the cylinder. Just remove the spark plug. The recoil cord should pull easily and oil will spurt out the spark plug opening. Pull until oil stops coming out. Check your oil level. Replace your spark plug and see if she starts.
2answers
Why will the pull cord not pull on my honda pressure washer gcv160?
You need to disconnect the pump from the engine to see if the pump is seized.
Jul 29, 2014 • Garden
I cant pull the cord in my pressure washer it feels like it stuck thiere is no pressure in it it wont pull
Take the sparkplug out and see if you can pull the cord then. If fuel comes out of the sparkplug hole the carburetor is leaking gasoline in to the engine filling up the cylinder causing the lockup. The carb has to be rebuilt. Another problem mice like to build nests around the flywheel which will prevent the engine from turning over. You have to remove the recoil housing and if there is a nest clean it out using a screwdriver or use a compressor to blow the mess out.
I try to pull the rip cord but it just gets stuck and i cant start it how do i fix it
IF YOU HAVE BEEN USING THE PRESSURE WASHER AND THEN TURNED IT OFF,THERE WILL STILL BE PRESSURE IN THE HOSE.YOU WILL NEED TO SQUEEZE THE TRIGGER ON THE GUN WHILE YOU START THE ENGINE.
2answers
Pull cord getting stuck
2helpful
Cannot pull start pressure washer. Cord will not
cord will not extend past 3 inches; just shut down after last use after 30 seconds.
Aug 31, 2009 • Garden
4helpful
Power Washer will not start - pull cord seems to be stuck
hi take out the bolts holding the compleat pull starter remove unit pull the cord if it wont move something is jamming it inside if it is ok then the fault is with the motor //seized or washer remove washer pump if engine turns over /pump seized the fault is 1 of the three you have now found out wich 1 starter, motor or pump it will take too long to go over all 3 get back when you have got this far merlinv12
The cord we pull to start the washer machine is stuck
Top Briggs & Stratton Garden Experts
Jay Finke
Jay Finke
john h
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
