RTO Mini Quads Logo
Posted on Mar 09, 2010
How to start 49cc, 2 stroke mini Harley motorcycle
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 25, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
523
Points
Hi i have just brought a mini harley 49cc bike
in red and black and dont have all the light the kill switch wire has been cut and on the brake leves not the brake wires have been cut for the lights or something there is no battrey on it ent got a key
how could i get it started
3 Related Answers
Anonymous
  • 43 Answers
  • Posted on Dec 31, 2009
SOURCE: mini gas scooter dont start
Does it have gas? just kidding. Even experienced mechanics forget that one. It may not be getting gas into the engine though. I use an old trick, disconnect the air box boot from the carb, cup the carb inlet with my hand, which is called a hand choke, and turn the engine over while hand choking. Your hand should get wet with gas. Remove your hand after a couple of seconds or so, it may start, or try. If not hit, pull the plug and lay it on a good ground on the engine, do not touch while cranking over the engine to check for spark. These are two of the basic requirements of an engine.
defadad
Harry Goodwin
  • 353 Answers
  • Posted on May 19, 2009
SOURCE: 49cc mini pocket quad wont start
if it has a kill switch make sure it is on, check that you are getting spark at the plug and have the right fuel in the motor.
Remove the air filter from the carbi and squirt some 2 stroke fuel directly into the throat of the carbi and try to start it.
hope this helps
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jan 11, 2011
SOURCE: hi there just brought a
Hello
Since this is covered under warranty do NOT attempt any repairs, if you tamper with the engine in any way you will void the warranty. Return it to the company that sold it to you for repair. Based on what you say you most likely have a fuel delivery problem, it is to rich, that means the engine is getting to much fuel, this causes the engine to flood out, the other possibility is the engine has poor compression.
1helpful
2answers
How do I fix my 49cc 2 stroke pocket quad it has
If you have replaced the spark plug then the possibilities are the ignition coil is weak or the starter mechanism is faulty.
See this site for details of parts.
Mini Atv Quad Parts 47cc 49cc Stock Replacement
2helpful
My 49cc wont fire over
My 49cc 2 stroke pull start scooter wont turn over
1helpful
2answers
2answers
49cc 2 stroke engine
I have a 49cc cateye mini bike it starts idles fina dn every thing but when you ride it it goes fine i can reach around 55 almost 60 with the stock engine but it seems to quit on my after about 15 mabey a little less sometimes and then will not start for about another half hour
Top RTO Toys Experts
Jay Finke
Jay Finke
ADMIN Eric
ADMIN Eric
Jerry Ross
Jerry Ross
Are you a RTO Toy Expert? Answer questions, earn points and help others
