Ive got a sony bravia. My Sky tv is on 'AV1', and until last night you could just turn it off and on and it would be on AV1 and Sky TV would come on. As of this morning you turn it on and its on 'TV' not 'AV1', so you have to use the original; remote control to change it from TV to AV1.
Any knowlegable types know how to reset it so that AV1 comes on when you it off and on again?
Without a remote control, you can't select its inputs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://homenol.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
SOURCE: sony bravia kdl40s2010u
A 4 flash indicates you have a backlight problem. Either the backlight inverter boards have failed or you have a backlight that has failed in the LCD panel. You will need a technician to check the set to determine which is the problem.
SOURCE: Remote code needed (sky+) to sync with Sony bravia kdl32v2000
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Sony Code: 0000
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
SOURCE: Cannot remove tv guide banner from Sony bravia 52'
Click on the display button (upper left corner) as a short term fix - it will turn it off immediately - not sure of how to permanently solve this though.
SOURCE: Sony Bravia No signal plus flickering image and
You know how to reset the tv to its factory setting, I think you are a technician. Second thing you can do is software update. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 . If it doesn’t work. Replace the Main board (UB board). Part # A-1547-086-A Cost approx $320.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
