My Frigidaire electric dryer GLER341AS2. The timer stops at 10 or 20 min. when I know it has run at least 30 or 40 min. OR my dryer will shut off with the timer at 20 min and the clothes are not dry (I usually set it at 40 min)
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Testimonial: "I have cleaned the dryer inside out but will now clean from the wall to the outdoors and see if this solves the problem. Thanks for the suggestion."
