I have a timex indiglo, mens watch, A christmas gift, and am having problems setting the day and date. The stem appears to have only one setting, notch
To set the time and date on your Timex Indiglo watch with a CR2016 battery, follow these steps:
Press and hold the stem (the button on the side of the watch) until the display begins to flash.
Use the stem to cycle through the different settings: time, day, date, and year.
When you reach the setting you want to change, use the stem to adjust the value.
Once you have set the time, day, date, and year to the correct values, press the stem to exit the setting mode.
If you have trouble setting the time and date on your watch, you may want to consult the manual that came with the watch for more detailed instructions. If you do not have the manual, you may be able to find a copy online or you can try contacting Timex customer service for assistance.
The watch should have only one stem on the side, if this is so, you pull the stem all the way out two clicks to set time, but you pull it out only one click to set day and date, at one click you turn one way for date and other way for date, to use indiglo you push stem in. If your watch has more than one stem please notify me. I hope this helps!
Mcdevito75 here, The stem on your Timex shou;ld have two (2) positions, slip a finger nail just under the crown and gently lift to the first position, it may take a little practice to get but you will. In this first position you"ll see by turning the crown one way you can change the date (number) and turning in the other direction you can change the month or day, if so, set the day and date to one (1) day before the day and date you want. Push the stem back in and lift the stem all the way to set the time of day, now cycle thru the watches 24 hours to set the day and date you want. Your Timex is now set and will change at the proper time of around midnite. If your Timex has the month and day you may have to cycle the 24 hours to reach the correct month other than that these instructions should help.
mcdevito75 here, Your watch (Timex) may have a 2 position stem. Push the stem (winder) all the way in, NOW just lift the stem a little to it:s first position, this should allow the date, (number ) to change, change that number to the date before the date you want, NOW pull the stem out to set the hands, rotate the hands to set proper date and time.
Your question brought a smile to my face as I had one also and had the same problem. It took me hours to finally figure out that the stem pulls out to set one thing and pulls out just a little more to set the next.
Hope this helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
On some analog Timex watches with a day/date window there are only two "pull-out" positions on the stem, one for changing the date and one for the time. To change the day you need to pull the stem all the way out and crank the hands through 24 hour periods until you get the day correct. Be sure that you have the correct AM/PM setting (if you are setting the watch after noon you need to advance the hands another 12 hours so that the day changes at midnight)
The trick is to turn the ring to the "Date" setting, Pull the stem out once for the Month and Date. Pull the stem out (hard, but gently) a second time for the Day of the week. Each pull will be confirmed by a 'beep. Be persistent and good luck.
