Question about Whirlpool LSR6232J Top Load Washer
Estate washer lid switch
How do I bypass lid switch (310003) on and Estate top load washer?
    Sergeant:
  • 215 Answers
Simple, dont as this could be very dangerouse. as machine will work. Think saftey as you dont want children, or your own limbs ripped from your body for the sake of saving a small ammount of money.
Posted on Mar 09, 2010
6ya staff
SOURCE:
Need to bypass lid lock Kenmore 2002 white red blue yellow which ones
Kenmore Whirlpool top load washer. lid lock issues - YouTube
? 3:34
https://www.youtube.com/watch?v=Vf1hVhpC8yE
Mar 12, 2013 - Uploaded by EurekaRecycler
Kenmore Whirlpool top load washer. lid lock issues ... The new one I bought or actually have a loan on the EXACT issue and I've only had it 3 ... cheap way to bypass the lid lock which is irritating, aggravating, frustrating on my ...
Kenmore Lid Safety Switch ( Temporarily Fix ) - YouTube
? 13:17
https://www.youtube.com/watch?v=UMlLqEF8EGM
May 20, 2012 - Uploaded by matttherepairman
This is a easy way to bypass a lid safety switch with-out cutting into the wire! Did your Kenmore Washer machine fill up and stop ? Your Lid ... +Jerry Munroe That is correct,,, You will not need to cut any wires Thank you for watching .... Kenmore Whirlpool top load washer. lid lock issues - Duration: 3:34. by ...
how can I disable the lock on my new top load Kenmore ...
www.shopyourway.com > Manage My Life > Questions
Jan 08, 2016 | Kenmore Washing Machines
How do i bypass the lid lock switch on my amana top load washer
I had that problem with a top loader and wedged half of a wooden clothespin between the lid and the switch to close it. Problem solved!
Feb 18, 2013 | Amana Washing Machines
Washer stopped working mid cycle. Filled up with water still. The washer will not make a noise. Completely dead.
Hello, Welcome to FixYa. The scenario you describe is usually associated with a faulty or broke lid switch...but I don't know if you checked that yet or if you know how.
The lid switch failure is definitely a common top load washer problem. Here`s how you can repair it pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...but it should cover yours)
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
Let me know how you make out. If this is something you think is not within' your scope of expertise please call a pro. I think you'll be fine with the tutorial video'
I will try to help in any manner I can of course as well. Good luck.
Thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
May 20, 2011 | Estate ETW4400TQ Top Load Washer / Dryer
How do u remove the safety which is under the lid of the washer
the washer lid is held in place with spring clips, use a putty knife to pry the lid up gently and expose the switch
Jul 29, 2010 | Estate TAWB600JQ Top Load Washer
My estate washer will wash but will not drain and rinse
Check lid switch. Close the lid gently, you should hear a slight click.
Oct 14, 2009 | Estate TAWX700JQ Top Load Washer
Top load washer says door open ( od )and will not
did you tested your led switch? you can bypass lid switch just have to be very careful after that....if it is a bad lid switch better replace it....unexpencive and more safe
Aug 25, 2009 | Maytag Washing Machines
My Estate washer will not drain.
Hey Don, If you removed the cabinet to get to your pump, you had to unplug the wire that connects to your lid switch. Did you make sure to plug the lid switch plug back into it's plug-in on top of your cabinet under control panel when you re-installed the cabinet. Your washer won't spin or pump water if this is the case. I'd check that first, then check the lid switch itself for proper operation. Happy to help, Tim. please don't forget to rate my help. Thanks.
Jun 28, 2009 | Estate TAWX700JQ Top Load Washer
My kenmore top loading washer 70 series wont go into spin cycle
check the lid switch some washers will fill and was with the lid open but will not spin, if the lid is closed manually actuate the lid switch or bypass it electrically, or replace it.
Apr 07, 2009 | Kenmore 22422 Top Load Washer
Lid switch isn't working
yes you do,yo can watcxh this video to show you how to remove the cabinet switch, maybye no t your switch but you cgain acess the same way/.
http://www.youtube.com/watch?v=6XIsK3W_Qcg
Mar 09, 2009 | Estate TAWX700JQ Top Load Washer
Estate top loading washer needs a lid switch replacement
I found one one NEW on ebay for 6.50 + shipping, total 12.49. Other parts places had them for a lot more. It wasn't too hard to install.
Nov 06, 2008 | Estate TAWS800JQ Top Load Washer
Whirlpool LSR6232J Top Load Washer Logo
299 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
