Well, after seven months I hope you have gotten this issue resolved, if not it sounds like your tv isn't on the AUX channel. Try switching your input to AUX. It should fix the problem
You must reset your PS3 in order to accept the new TV configuration.
If the video output settings on the PLAYSTATION3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
Then, with only the PLAYSTATION3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
Hope this helps please remember to rate my response, thanks!
You need to turn on the tv and set to HDMI, Then power on the PS3 and hold down the on (standby) button until it beeps again twice and it will pick up the TV and display on the HDMI,
If this doesnt work go to system settings and video settings and set the output to HDMI.
He is full of **** trying to scam you. It sounds like your disc drive is out of alignment with the top part of the disc drive so the clicking your hearing is the bottom of your disc drive trying to eject and the top is holding its on as the top has sliding parts that meet perfectly with the bottom part of the disc drive so it sucks the game in and out. You need to open it yourself with a philips head screwdriver you dont have to worry about the motherboard or any other part just take the drive out undo the ribbons connect the drive to the motherboard then it should pop right out. Been awhile since I took a slim apart they dont break as often (yet). From here you should have a metal caseing over the disc drive maybe not with the slim. You pop the metal caseing off the you have a plastic disc drive. Take the top part off maybe requires small phillips screw driver. Since you have a disc in it when you take the lid off hook the cables back to the ps3 motherboard and to the cd drive. Now press eject with the top lid off. Then put the top lid back on and insert a disc it should work. Then just put it back together. Theres a little motherboard on that cd drive do not short it out on anything. You can do this if you cant worst is youll have to buy a new cd drive from the repair shop you mentioned. Then they should charge to much labor to put it back together as you had it apart when you got there. But you should beable to do it if you need help taking it apart just google or youtube slim ps3 disc drive repair or how to take apart slim ps3. Hope this helps if not let me know.
if the disc is spinning with some clacking noise then its all right,use the manual eject button 3 to 4 times.Now the disc should be sited on the disc plate.If you think that this works but not through the software then update the firmware.On new slim PS3 disc stuck,it doesnt void your warranty. Thanks for using Fixya
Call sony 1-800-345-SONY (7669) ask them what to do and their price on it!
There is a fix but it normally requires you to take the seal off and if you dont want to attempt that then you can send it back or sell it to me ;) I do buy broken ps3's.
If you are willing to have a go at it via yourself let me know I can help you get the parts and fix it!
