I am sorry to disagree, but some information in the previous post is INCORRECT. DO NOT connect the output of the mixer to the MIC input. The mixer generates LINE level output that should go to the LINE-IN on the sound card. If you connect the mixer to the mic input, you will damage the sound card. MIC level inputs have an additional amplification stage.
Dan
Ok a mixer can be connected to a computers sound car via the outputs/inputs on the back of the mixer.
Then input comes from your sound card where the spears would go. You use a RCA to 3.5mm jack www.radioshack.com for both the inputs and outputs.
output you want to go to you mic input on the sound card if you want to broadcast.
But if you just using this for like a dj setup all you need to do is take the output from you soundcard into the inputs on this.. Then if you want to connect this ti a amp/reciver you take the output from the mix to the AMP..
I hope this explains how to do this please do rate the solution if you have questions please to reply to me. thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
How do I connect my mg102c to my computer ?
