You could try pressing the space bar key back into position since it has a small clip on the same part where the space bar key was held in position and incase if the key still pops off you would need to contact technical support to get the keyboard replaced.
I'd suggest flipping your notebook on its side and then over, lift/pull the space bar slightly with a flat screwdriver or other thin, flat object. First shake, then spray compressed air in the area.
Hopefully, something is lodged (like a paper clip or other small object) and will be removed.
If not, the space bar cannot be replaced, unlike other keys. So, you would need to replace your keyboard.
The space bar on any PC is a single button you may need to make sure your keyboard is clear of any debris If that doesn't fix issue you will probably need to replace keyboard which is very easy to do. [email protected]
The space bar key is connected tothe keyboard a little bit differently then any other key. There is a metal retainer connectedto the space bar key (on some keyboard models). Separate the retainer from thespace bar key with a flathead screwdriver. Install the retainer back inplace as it shown on the picture. You have to engage the retainer with thesmall hooks on the keyboard. Put the space bar key back inplace and gently press on it with fingers until it snaps back in place. That’s it. The space bar key isinstalled back in place and should work as before. If you still cannot fix yourkeyboard, then you’ll have to find a new oneand replace it. Pleas rate my solution on fixya if you are done.
